TCL 75S425 lines
  • idigg
    • Sep 2021
    • US
    TCL 75S425 lines
    Hello Bad Caps. My two year old TCL TV all of a sudden has some crazy colors with vertical lines, and a single horizontal line. No damage to the TV, it just freaked out and did this. Powers on, but can't see any menu.
    https://imgur.com/wdxQ6fD
    Any ideas how I could fix this? Much appreciated
    Justin
  • nickgronk
    • Apr 2021
    • 32
    Re: TCL 75S425 lines
    Thats a bad panel or connection from tcon to buffer boards. Try unplugging either side of the tcon board (there are two ribbon cables on the tcon). See which side is causing the problem. May be able to fix with tape. Here's a link to a video where the guy has the same problem (almost) and fixes with tape: https://www.youtube.com/watch?v=pfrRhw7-ZII
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • advant
      by advant
      02-03-2020, 12:25 AM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • Stanley1843
      Screen Display Vertical Multicolor Lines
      by Stanley1843
      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
      06-29-2024, 11:54 AM
    • Daren87
      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
      by Daren87
      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
      08-13-2023, 03:25 PM
