UA55H8000 - bad capacitor on panel (SOLVED)
  • yairitz
    • Nov 2014
    • 5
    • Israel
    Owned a Samsung UA55H8000 (curved) LCD.
    Picture disappeared, sound still there.
    Took it apart, and measured the backlight LEDs:
    8 sets altogether: 4 measured 90V each, 4 measured 30V each. Seems OK.
    Watched the T-CON, and saw only 2 of 3 LEDs light up.
    Ordered a replacement on eBay (not 1:1, but close enough).
    Arrived, same 2 LEDs on, 1 off.
    Unlikely to have same bad T-CON, right?
    On the T-CON measured 12V (input) and 1.2V, 2.5V and 3.3V around - all OK.
    But no other Gamma voltages...
    Then, when measuring the DC-DC diodes, realized that DD02 had a ground short on both sides. Odd.
    And with the panel flat cables off - the short went away!
    Turns out that QD01 is a 6-pin MOSFET, SW controlled, switching the 12V into the panel (and to the Gamma DC-DC convertor chip). DD02 is connected to it's output.
    The culprit was the panel - showed a 1 Ohm resistance to ground on it's 12V supply input (fed by QD01)
    Disconnected it from the T-CON, and connected a 5 Amp supply, only to watch bubbles under a 0.1uF bypass capacitor (see picture!) on next to one of the chips...
    Cap removed, old T-CON working, TV back to life.
    Happy days
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
  • netgearnetgear
    TCL 43S423 TCON OR PANEL FAULTY???
    by netgearnetgear
    Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
    08-20-2025, 06:04 PM
  • advant
    by advant
    02-03-2020, 12:25 AM
  • iglitare
    by iglitare
    09-04-2025, 07:13 AM
  • mmartell
    General Questions on the Relationship Between Mainboard, TCON and Panel
    by mmartell
    My goal here is to be able to use boards on hand to swap into faulty sets when the faulty board is not obvious.
    I will start by asking what is the format of the output from the mainboard and is it generic in any way or does it vary by manufacturer and/or model ?
    And as far as I know a tcon and panel must be a matching pair because the timing of the signals and the voltages required to drive the panel are specific to the panel itself. (That may be a blanket statement that isn't true in some cases where the panel creates its own sub-voltages on its panel boards?)...
    01-06-2024, 01:32 PM
