Vestel 55” 17mb130s help needed
  • Liammif
    • 10
    I have a vestel 55” chassis VES550QNDS with 17mb130s main board, the tv brand is Teac and its the LE55A4S1UHD. Originally had blinking standby light of death. Tried a panasonic firmware which worked, loaded to language page and I had thought it was frozen, turned out the remote obviously didn't work because it was panasonic firmware (stupid me). I tried loading another firmware I was sent which corrupted or something and now as soon as the tv is plugged in it does the blinking standby light straight away without trying to power on. I can hold the ok button on my remote when I first plug the tv in to update the firmware but now it does not recognise the firmware at all.
    What are my options from here? Im obviously a noob and only learning, my only tv repair experience is changing bad caps on plasmas haha.
    Any help is much appreciated.
    If it comes down to having to replace my main board, can I use any 17mb130s providing all the connections are the same or does it have to be the exact model.
  • Liammif
    • 10
    Re: Vestel 55” 17mb130s help needed
    So after more research I've learnt I have bricked the main board. I suppose this isn't an easy fix at all so my best bet is finding a replacement board. I read that the boards are interchangeable across vestel models however the it may display differently due to variances in models??
    • lotas
      • Jan 2016
      • 4585
      • Russia
      http://www.mxmee.com.au/index.php?ro...roduct_id=6185
      • Liammif
        • 10
        Yeah I found that earlier but it was false hope, unfortunately it is out of stock and I cant find my exact board anywhere. Hence why I was hoping there was hope of using an identical board from a different brand Vestel.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          If you can find a mainboard that uses your exact lcd panel numbers it may work
          • Liammif
            • 10
            Awesome, ill soon find out, have ordered a board from overseas, should come in a couple weeks. Ill post back with my results for those wondering!
            • Liammif
              • 10
              Update, different model TCON board but for same chassis tv worked perfect. Had an extra input which I had to drill a small hole to fit in my tv back panel. Hopefully this helps anyone who is in my position!
              • hosbulduk
                • May 2020
                • 17
                Because your remote control's settings were changed when you installed new software, your old remote control did not work, so you can buy a Panasonic remote control and solve your problem.
                When you try to install new software, the OK button on your current remote control does not work because the Panasonic remote control setting is still active.
                The software version is very important on mb130 motherboards (v3 v5). If you install the wrong version, your motherboard will fail.
                • piernov
                  Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                  by piernov
                  Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                  I suspect corrupt firmware but I haven't been able to find anything for this TV.
                  TV model: Finlux 65-FUC-8060
                  Mainboard: Vestel 17MB130S 23473048
                  Panel: VES650QNTS-2D-U11
                  At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                  06-01-2024, 12:57 PM
                • stav242
                  BUSH DLED43IHDHDRS 17MB130S Firmware needed
                  by stav242
                  i have a BUSH DLED43IHDHDRS.
                  the MB - 17MB130S is not booting - it did once then wont boot again.
                  Suspect its the corrupt firmware issue.
                  Where can i find the correct firmware for this model ?
                  11-02-2022, 03:39 AM
                • massimomax
                  Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                  by massimomax
                  Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                  spero che qualcuno può averlo per riprogrammare eprom. grazie
                  Post in English !!!
                  I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                  02-28-2025, 07:27 AM
                • anlu
                  Vestel Firmware - Toshiba 32W133DN
                  by anlu
                  Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                  Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                  02-04-2023, 12:59 AM
                • comptek
                  Vestel 17mb110p Firmware Needed
                  by comptek
                  Hi guys this Tv is just flashing
                  I believe it's the firmware crashed wondering if there is a core update or something available
                  Gary...
                  02-09-2023, 05:26 AM
