Hisense 50" 50k20DG Won't turn on!
  • Megan0
    • Aug 2021
    • 28
    • united state
    Hi, I have Hisense 50" 50k20DG it won't turn on but when I connect power cable to the tv the red indicator under tv turn on and off for 1sec. could you help me what is the problem? Do I have to change the capacitor or something?
  • neilc6
    • Nov 2015
    • 1550
    Re: Hisense 50" 50k20DG Won't turn on!
    If you have stable standby voltage, main board is suspect if TV is not turning on. If it has an eeprom, you can try freezing it with an upside down can of duster.
    • pajdek
      Lenovo Y700-17ISK turn on and off
      by pajdek
      Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
      09-20-2023, 02:49 AM
    • RdeveLabs
      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
      by RdeveLabs
      To all the members here...
      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
      05-05-2025, 04:59 AM
    • robante15
      Acer Aspire 4520 won't turn on after reboot
      by robante15
      Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
      It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
      The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
      If I remove the...
      04-06-2024, 06:50 PM
    • Ledgurra
      MacBook Pro A1425 it doesn't turn on
      by Ledgurra
      hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
      thank you all
      11-09-2025, 06:07 AM
    • tmhobadcap
      Hisense 58H6550E - Freezes/Won't turn on
      by tmhobadcap
      I have another tv to fix for my friend. It is a Hisense smart tv. After turning on, it will freeze or stuck on certain screens. However, when it is connected to a tv box, it will automatically connected to it and play without any problem. I wanted to go to the menu and reset the tv. But it just freezes before I reach the reset menu. I have tried the hard reset methods, but no luck. I guess the main board is with problem. Will reflowing one of the chip may fix the problem? If yes, which chip should I try reflowing?
      The followings are some videos showing how it freezes.
      https...
      02-12-2023, 09:19 PM
