B109-901 Tv Power supply no standby voltage - TCL 40C35F
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Hi, I've got a B109-901 power supply that is absolutely dead, it has no standby voltage and the main bridge rectifier (highlighted in red) has no ac input voltage, after prodding around for a bit I found a relay that is responsible for delivering mains voltage to the rectifier (highlighted in blue) which for some reason isn't closing when I power the board on, I tested the relay and confirmed that it is good however it seems to have no voltage on it's coil. I followed the traces on the PCB and one of the pins of the relay's coil seems to connect to the rectifiers DC - output while the other goes onto a very complicated array of surface mount components, any ideas on what purpose a relay like this serves? why would you want to disconnect the rectifier from mains?
    • 21592
    Re: B109-901 Tv Power supply no standby voltage
    Whats the TV brand ,and model number .
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      It's a TCL tv model number 40C35F
      • R_J
        • 9588
        The standby ic is likely the 8 pin ic (U401) near the smaller transformer, I suspect there is a low value resistor that feeds it that is open. The picture is too small to make out the model number of the board but it looks like a dafron 4h.B1090.701
        post the number on the ic and we can look up the datasheet for the pinout.
        I suspect D204 & D205 & CE203 are the dc supply source for the standby ic, so check the voltage across CE203.
        • Gjackson
          • Aug 2021
          • 134
          • Malta
          I really appreciate the reply, I've attached some more detailed photos below of the board model number and the IC. The IC is a 7 pin ST VIPER17L, one of the pins is missing however this is intended as there is no hole on the PCB for it. I've measured the voltage across cap CE203 and there is a steady 100v DC. There are 4 more IC's on the bottom of the PCB (images below) 2 on the cold side and 2 more on the hot side. I've also attached the datasheet for the PSU below, it's not for the exact model that I have but the component names seem to match, here are the IC names relative to the images below:
          these might be wrong as it is really hard to read them!
          1 (U701). 324
          ST p777951
          2 (U600). 0Z9972GN
          A93YRL.1G
          0924AT
          3 (U301). EA1530A
          SD9C103
          Hn69452
          4 (U201). L6562A << this one was very hard to read, 2A might be wrong
          ST EZ -- (unreadable)
          • Gjackson
            • Aug 2021
            • 134
            • Malta
            Oops forgot to add photos
            • Gjackson
              • Aug 2021
              • 134
              • Malta
              Re: B109-901 Tv Power supply no standby voltage - TCL 40C35F
              Update:
              I searched around a bunch of resistors both smd and through hole
              I found 2 resistors (R425 and R307) that have values that are off,
              R425 should be 180kohm and is 122kohm
              R307 should be 100kohm and is 87kohm
              can this cause issues?
              Thanks.
              • R_J
                • 9588
                The smd ic's on the back (pimary side) are for pfc and the main power supply driver, you need the standby voltage first. Using the negative of the bridge rectifier, check the voltage on pin2 of U401 (VDD) Voltage across CE405, If this cap is bad the ic may not start.
                The schematic is different and does not use the viper17l ic.
                Post a picture of the trace side of U401 so I can trace the circuit.
                • Gjackson
                  • Aug 2021
                  • 134
                  • Malta
                  Ok so I measured 6v DC on VDD of U401 and 6v DC across cap CE405, If you want I can take the cap out and see if it has the correct capacitance value.
                  Thanks.
                  • Armando Urbieta
                    • Apr 2024
                    • Paraguay
                    Thanks.
                    Conseguiu resolver o problema dessa placa , estou com o mesmo sintoma
                    • Armando Urbieta
                      • Apr 2024
                      • Paraguay
                      Thanks.
                      Conseguiu resolver o problema colega ??
                        Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                        by sam_sam_sam
                        I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                        https://www.ebay.com/itm/116497313155?var=416785404161
                        Here are some of the description from the eBay seller
                        The main parameters:
                        1. Product name: High-power non-isolated DC boost module power supply.
                        2. Product model: 100A2000W.
                        3. Input voltage: DC12V-60V.
                        4. Input current: 100A (maximum)....
                        05-18-2025, 09:45 AM
                      • reessi
                        JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                        by reessi
                        I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                        You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                        Years ago it had some bulging caps...
                        04-26-2021, 11:42 AM
                        Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                        by sam_sam_sam
                        I was working on this CNC machine today found no keyboard functioning no control relay powering on
                        The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                        Found shorted diodes on main controller relays there are 3 of them that...
                        01-07-2023, 05:43 PM
                      • CuriousJohn
                        Burco boiler power problem
                        by CuriousJohn
                        Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
                        Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
                        This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
                        12-22-2024, 10:25 AM
