Good morning, sorry me again. Same tv, similar issue.
Probably about a few weeks ago the TV seems to be locked up in a boot cycle. It turns on, no sound and then turns off and starts the whole cycle again. I've opened up the. back and can see the backlights turning on. Its funny though as when I disconnect the two straps connecting the left hard board (as you look on the back of the TV), the boot cycle stops and it does turn on and I can hear the boot up sound, however no video?
Any thoughts, any help would be greatly appreciated.
samsung ue55nu7021k backlights working but blank screen
Re: samsung ue55nu7021k backlights working but blank screen
Thank you to all.Leave a comment:
Thats great news the replacement board ixed the issue.
Reagding ficing the other board my guess as it would not take the fimware/software update one of the ics is faulty so may not be cost effective for you trying to repair it if you have not got the replacement ics/hot air station, solder/flux etc etc .Leave a comment:
So the board arrived this morning! I replaced the old one and the TV is back up and working!
Thank you both for your help on this, I had assumed my TV couldn't be repaired! Its fairly simple as well, as long as you get the right parts.
Can I ask if it's possible to determine whats wrong with the old one, can you test the various components in some way?Leave a comment:
https://www.youtube.com/watch?v=Zl5eOQ-ASxY
https://www.youtube.com/watch?v=uOr8rLj_rTk
https://www.youtube.com/watch?v=w8lu5XAVHAILeave a comment:
Anyway, any videos or advise on how to change board? There doesn't appear to be any boards and don't want to try and force it off.Leave a comment:
Yes, right on the first link: https://www.ebay.co.uk/itm/294652623...gAAOSwfYVhwOBJLeave a comment:
Also, how can I get email notifications when someone posts in the thread?Leave a comment:
Sorry I'm not sure but the link I posted doesn't work but apologies for asking but am I right to order the first link shown by Vince in post 89.
ThanksLeave a comment:
ok, just caught up. I'm going for the first link vince suggested:
Correct?
Thank you all!!!Leave a comment:
Good spot on that connector i was on phone so didnt zoom in (see it now im on laptop) so yes ignore the second ebay link!Leave a comment:
this just gone on ebay
looks like rite one?
also this even cheaper does not mention lcd panel number though
https://www.ebay.co.uk/itm/334257416...4AAOSwLalhu5eY
On the first link, he also has a 30-day warranty.Leave a comment:
Its the Smart TV motherboards. They are all very expensive.Leave a comment:
by dicky96Hi guys
I'm trying to fix this laptop screen
Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
OK so I have the original screen which works but has lines across the bottom quarter of the screen
I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would... -
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
by BloopetaSamsung UE55JU6800K with no image on screen.
I have had this TV many years without fault, however aprox 6 months ago I fitted a new set of backlights as some of the lens caps had fallen off.
Was working fine, until 3 days ago, when watching TV the screen just went blank (still illuminated)
I turned the TV off and left it around 12 hours, and when turned it on again it seemed to work perfectly again. After around 45 mins the screen went blank again.
Left it off overnight and turned it on, and the Smart TV logo came on as normal, then screen went blank.
by bohabohaHi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
anyhow i couldn't t read anything else
the backlight is on strong and the screen does not get dark or very dark but no pictures
the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
by 4thommoHi all,i have this problem and so far I have visually checked the main board and flashed the main board with the files in the first picture. The flash seemed to go ok,first the front red LED flashed quickly and then slowed up before the TV turned itself off and on but it is still the same. I see there are exact matching main boards available but I don't want to commit to that incase it's something else. Any help would be greatly appreciated.
PSU 17IPS62
MB 17MB110P
Panel VES315WNDS-2D-N144 Photos - Loading...
