JVC LT-40N530AA dumb TV - faint image and weird buzzing noise
+ More Options
Posts
  • zump
    • Feb 2021
    • australia
    Hello
    Turned on this TV one day and the image is VERY faint. And the TV is making a strange buzzing sound. Eveything else seems to work though!
    VIDEO
    https://www.youtube.com/watch?v=ncXlyb8xS78
    The high pitched buzzing is a bit hard to make out, but it's definitely worse in real life.
    What component is broken on the board and can I replace it?
  • stvhop
    HP1955L Buzzing noise & interference
    by stvhop
    Hello, This is my first post so please forgive me if I miss out some vital info.
    I have a problem with my HP1955L monitor from 2005.
    The first thing to say is that it is still basically working, ie the picture is fine.
    However it makes an electrical buzzing sound. I know all monitors make some some of hum, but this is louder and more of a buzz.
    The volume of the noise seems to be dependent on how hard the monitor is working; switched on with a blank screen -> no sound; small dialog (like OSD only) -> minor buzzing; full screen picture -> loud buzzing.
    11-07-2020, 07:13 AM
  • Orion Bardier Skylar
    Adding Bluetooth module to Woofer buzzing noise
    by Orion Bardier Skylar
    Hi, I got this Woofer,Name TBT, which damaged its Radio module, then was added a Bluetooth module from the market(history from client). Then recently was brought to me with very low sound and heating problem. I changed subwoofer Speaker which had impedance of 1.2 instead of 4ohms rms and the bass ic KA2206B. Sound is back but buzzing and hissing sound present even when muted. How can I get rid of it?
    03-06-2024, 02:35 PM
  • Antony2023
    Monitor making weird noise when charging resolution or in standby mode
    by Antony2023
    Hello, guys i need some help, i have an old fujitsu siemens LCD monitor, and is making weird noise when is changing resolution or in standby mode.
    I open it up, to see if it is any hardware damage, but i only see 2 capacitors bulging on the logic board, i'll probably change them. On the power supply circuit board, only one thing caught my attention, the transformer seems to have leaked something out of it and the mess around it. Do you think there may be a problem here?...
    01-07-2023, 09:24 AM
  • tony359
    by tony359
    11-28-2023, 05:18 AM
  • MegaZAC
    Onkyo TX-SR805 noise in one channel
    by MegaZAC
    Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
    Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
    There's some logic behind it. As soon as I select an input I get only left...
    04-23-2025, 10:09 PM
