Question about panasonic TXL42ET60E
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Hi to all
    Has anyone opened to change leds in the above model?
    Because it was given to me by someone who had it for throwing and I want to make it
    But I found that it has a single sheet reflector or diffuser
    and a row of leds on the slopes
    6916L-1265A 42 V13 LBA REV 0.8 LC420EUD (FF) (F2) 6922L-0077
    does anyone know about it?
    I'm just asking for confirmation because it seems strange to me to have only one leaf reflector or diffuser and a row of lent
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • BigPete
    Panasonic Heatpump Dryer Repair
    by BigPete
    I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
    The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
    In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
    Unfortunately the whole machine has to come apart to fix it.
    I have...
    11-01-2025, 06:40 PM
  • V3dran
    Diffuser/LPG for UE50NU7022KXXH
    by V3dran
    I'm trying to repair a UE50NU7022KXXH with a cracked diffuser/lpg and now also with burned leds
    There are 4/5 white spots on the bottom that are not visible since the left side is dark now so I want to change the diffuser/lpg
    Looking the samsung spare parts, I see that there is a DIFFUSER PLATE and a LPG so I'm wondering what is really broken?
    https://www.samsungparts.eu/samsung-...n61-15659a.htm DIFFUSER PLATE 1125x625x2,5mm
    https://www.samsungparts.eu/samsung-...n61-15661a.htm LPG 1101x619x2,7mm...
    06-26-2025, 01:54 AM
  • Andre Gilbert
    by Andre Gilbert
    Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
    Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
    11-20-2024, 08:52 PM
  • AquaMan Ua
    Problem with PANASONIC CF53 laptop after changing BIOS settings
    by AquaMan Ua
    Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
    05-17-2025, 09:40 AM
