bright spots after convert lcd to led tv
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    I change my lcd (fleurecent lamp) tv philips 32pfl5405 inches to led tv
    and i have the problem with bright spots like the bellow video
    Can someone tell me tips to reduse this problem ?
    https://www.youtube.com/watch?v=dX-z...w_HdaJ&index=1
  • lotas
    • Jan 2016
    • 4881
    • Russia
    Re: bright spots after convert lcd to led tv
    It is necessary to put a reflector, a diffuser
    • alfatv
      • Sep 2020
      • 353
      You can have this problem if LED's are without lenses.
      Also some lenses work better than others.
      In some cases LEDs should be super tiny to work properly with lenses.
      You can get improvements with more LEDs, more distance between LED's and screen (not practical).
      Do you have diffuser sheet under screen? You may need to add more of these, you can get them from another TV with broken screen.
      • Xristakis795
        • Mar 2021
        • 162
        • Greece
        thank you both very much for your helpful tips
        Someone else told me to add acrylic sheet
        as far as photography is concerned can I buy from here?
        https://www.aliexpress.com/item/32946904091.html
        something else i want to ask under the flueresent cathode lamp that this white sheet had in the beginning is not reflective?
        I have placed above this the leds are wrong;
        Do I have to drill holes like on a regular led TV or discard this sheet and use a new one from the above address?
        • alfatv
          • Sep 2020
          • 353
          It would be helpful if you could post pictures of your setup and how backlight is currently working
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            Sir I do not have photos to show you at the moment but the result of the conversion is exactly the same as the address I gave you in the video above where it says
            notice you can see the bright spots but its not too bad
            • CapLeaker
              Leaking Member
              • 8352
              not that bad? Looks pretty awful to me! I think you need to change the lenses on top of the LEDs first. Then play around with the reflector etc.
              • Storyteller12
                • Jun 2020
                • 625
                You are trying to make something work that was never supposed to be that way.
                It’s going to be a try and see kind of situation. I don’t think anyone here has tried to convert a TVs backlights.
                It’s cheaper to just buy a new tv, especially a 32” Phillips. Wouldn’t even waste my time
                • Xristakis795
                  • Mar 2021
                  • 162
                  • Greece
                  thanks for the answer sir
                  Do you know more suitable senses or led strip to suggest me ?
                  • gabiz_ro
                    • Mar 2011
                    • 171
                    • Romania
                    Search for cheap 32" TV with LED backlight and broken screen
                    Harvest LED's , diffuser sheets and white background reflector also
                    Pay attention to diffuser sheets order and orientation.
                    Adapt to your LCD frame.
                    Solve power for LED's
                    Job done.
                    • Xristakis795
                      • Mar 2021
                      • 162
                      • Greece
                      thanks for the answers
                      • Sus256
                        HISENSE 65E7KQ PRO - no boot
                        by Sus256
                        Hi all!
                        HISENSE 65E7KQ PRO
                        RSAG7.820.13512 - chassis
                        MT9618BAATAB - cpu
                        RSAG7.820.12059 - power
                        HD650Y3U77 - panel
                        KLM8G1GETF - emmc
                        The TV does not turn on, the standby indicator is on. All voltages are present.
                        Emms is dead. Not readable, not detected.
                        Replaced emmc.
                        But with another dump there is no launch
                        Terminal log
                        UART
                        AC_ON
                        RPMB key is not yet programmed
                        HASH1_VERSION=0x00000000 64bit
                        E-B
                        FDE enabled
                        layout pattern onebin by SAR7,0...
                        06-01-2025, 02:11 AM
                      • howardc64
                        UN55NU7100F failed edge lit LED bar, poor quality replacement LED bar AND bulging cap on PSU
                        by howardc64
                        Just typical LED bar failure repair but discovered a couple of things worthy of posting
                        PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
                        2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band Can't detect when testing the LED bar along...
                        10-13-2025, 05:56 PM
                      • tmhobadcap
                        LG 55UJ6200 TV with bright spots
                        by tmhobadcap
                        There are a few bright spots on the screen. I checked on youtube and most probably they are caused by the led lens fell off and can be fix by gluing back the lens.
                        But one of the bright spots is actually a bright ring (circled in red as shown on the attached photo). That means a bright spot with a dark center. What is the cause of that bright ring and how to fix it?...
                        03-06-2021, 08:54 PM
                      • Pipolups
                        Corsair K70 LUX RGB dying LEDs
                        by Pipolups
                        Hi there !
                        I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                        Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                        10-08-2024, 11:58 AM
                        HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) Specification for Upgrade or Repair
                        This specification for the HP ENVY x360 ENVY x360 Convert 15-ds0502saBundle 6TD07EA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ENVY x360 Convert 15-ds0502saBundle 6TD07EA boardview and ENVY x360 Convert 15-ds0502saBundle 6TD07EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                        09-06-2024, 11:17 AM
