Samsung/Vizio PS-42 power supply
  • Maxxarcade
    • Jul 2006
    • 973
    Working on a cheap Vizio VP422 that has no power.
    I have a full set of spare boards, but it appears that I have two bad power supplies. They are Samsung model PS-42.
    The one currently in the TV has no blown fuses. The relay cycles when power is applied, but no voltages are present other than the PFC B+. The LED flashes twice repeatedly.
    The other PSU has a shorted IC and blown fuse.
    Any idea where I might find a schematic for this set, or at least the PSU?
    This thing is a nightmare to work on physically... Once the screws for the back cover are removed, the whole case falls apart. The Planar TV's I worked on recently (also built by Samsung) had nice strong frames and normal back covers.
  • cadiman
    • Mar 2010
    • 397
    Re: Samsung/Vizio PS-42 power supply
    The power supply with the blown fuse my be easier to troubleshoot. shorted caps or mosfets. I am new to tvs. I love dead stuff. Can`t make it any worse and almost always easy to troublshoot. is this a plasma or lcd? again, still learning!
    • cadiman
      • Mar 2010
      • 397
      Also the 2 flashes needs a defenition. Should tell you what area to start looking at.
      • islandboy53
        • Jan 2011
        Can anyone help me locate the power supply board for the akai psp 4298, which seems to be the samsung b4k 50. And at what coast.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
          07-01-2024, 06:34 AM
        • cheeky2
          Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
          by cheeky2
          This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
          I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
          Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
          06-15-2025, 05:12 AM
        • JimBanville
          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
          by JimBanville
          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
          09-13-2023, 07:21 AM
