Sharp LC70LE755U - Intermittent backlight flickering and loss of sound.
  • TheForgottenKing
    • Apr 2021
    • 16
    Hello everyone, first time posting here so I hope I'm doing everything right.
    I just came into possession of a Sharp Aquos LC70LE755U. It was free for me, so with the stand and power cable I only have $30 in this. As such, I'm trying to repair it for cheap.
    It works most of the time perfectly, except for an issue with what I think is the power supply. After anywhere from 10-30 minutes of usage, the screen backlight will flicker briefly, and the sound will completely stop working. The sound doesn't start working until I unplug the TV, wait a few seconds, and plug it back in. In addition, at lower brightnesses, the screen backlight flickers randomly.
    From my research I've gleaned that both the backlight and speakers are hooked up directly to the power supply board, and now I'm wondering where to start looking as to repairing it. I'm also trying to get a board for cheap and just swap it in.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Sharp LC70LE755U - Intermittent backlight flickering and loss of sound.
    Some photo's of your circuit boards could prove useful.
    Have you taken any power supply voltage measurements.
    When the backlights and sound go off does the remote control still work.
    With a bright light shone at the screen (at an angle) can you see if the picture still there.
    Does the led(s) on the front flash?
    • TheForgottenKing
      • Apr 2021
      • 16
      I'll disassemble it tomorrow before work, and try to get some up-close pictures. Is there any areas of interest?
      I haven't taken any voltage measurements. I'll try to do so but the intermittent style of the problem might make this difficult.
      The remote control continues to work, and the TV continues to properly display an image. The backlight and image stays on, it's just a quick flicker and the image continues to work after.
      • alfatv
        • Sep 2020
        • 353
        Remove power board and check solder joints. I can't guarantee the problem is there, but this is one of the first things to try.
        • TheForgottenKing
          • Apr 2021
          • 16
          Will do this as well. Would it be worth trying to heat the board in an oven to reflow the joints?
          • R_J
            • Jun 2012
            • 9623
            Originally posted by theforgottenking
            will do this as well. Would it be worth trying to heat the board in an oven to reflow the joints?
            NO, DO NOT do this to the power supply board!
            • TheForgottenKing
              • Apr 2021
              • 16
              Will do this as well. W̶o̶u̶l̶d̶ i̶t̶ b̶e̶ w̶o̶r̶t̶h̶ t̶r̶y̶i̶n̶g̶ t̶o̶ h̶e̶a̶t̶ t̶h̶e̶ b̶o̶a̶r̶d̶ i̶n̶ a̶n̶ o̶v̶e̶n̶ t̶o̶ r̶e̶f̶l̶o̶w̶ t̶h̶e̶ j̶o̶i̶n̶t̶s̶?̶
              Will not do this. Pretend I never said that. Is there a particular reason this is a bad idea?
              • TheForgottenKing
                • Apr 2021
                • 16
                Unfortunately I was wrong about my statement of the speakers being attached to the power board, they are attached to the main board. I've attached an image of the block diagram.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  I would take the voltage readings at the power supply connector PD pins 1 to 24 when the set is working and again when you lose the sound.
                  Have you checked if audio is still available at the headphone output when you lose the speaker sound.
                  • nomoresonys
                    • 12328
                    • U.S.
                    For re-flowing solder joints on powerboard if needed, just grab a 10-15 dollar soldering iron from a local hardware or a big box store, some even come with some solder included.
                    • TheForgottenKing
                      • Apr 2021
                      • 16
                      I've attached images of the power supply, main board, and tcon board respectively. Please do specify if you want a closeup, but I don't see anything immediately obvious.
                      • Diah
                        • Feb 2013
                        • 6553
                        you wrote " at lower brightnesses, the screen backlight flickers randomly"
                        can you upload focused clear photo on the label print chart of the backlight sockets L1 & L2 on the powerboards.
                        • TheForgottenKing
                          • Apr 2021
                          • 16
                          LED pinout:
                          Pinout to the board:
                          At this point I've bought a cheap replacement power supply just to test if this one is the problem. I'm hoping it's not the main board.
                          For anyone interested, I'm using this manual.
                          • Diah
                            • Feb 2013
                            • 6553
                            LED flickering never being powerboards neither mainboards. or bad soldering too..the LED self are the issue.. one or more of them have spark , which result complete picture flickered and sound cut off too , later on let the reset LED Flickered even at low backlight level. it could be too at one of its sockets behind the screen
                            • TheForgottenKing
                              • Apr 2021
                              • 16
                              Where should I look, and what's the process for checking the LEDs? And why would this cut off the sound at the same time?
                              • Diah
                                • Feb 2013
                                • 6553
                                cutting the sound could be happened as i think because you were using the tuner as source... if you use HDMI signal or usb media it will not happened.
                                spark will effect on signal of tuner. if this signal disrupted it will cut sound... look like bad receiving areal signal. if you use external signal such HDMI or other i mentioned before... i dont think the sound will cut off. just the led will keep flickering as you have now... try and test.
                                • TheForgottenKing
                                  • Apr 2021
                                  • 16
                                  The sound issue occurred over both HDMI and 3.5mm, I've been using this with a PC and laptop. I've got a new power board and will test that, I suspect it might be an issue with something that powers the 13V rail which seems to power the speakers.
                                  • Diah
                                    • Feb 2013
                                    • 6553
                                    at which resolution..?
                                    • Diah
                                      • Feb 2013
                                      • 6553
                                      well, i think the best way copy movie on usb flash drive and play it direct on the tv.. to terminated any out source could be the reason.
                                      • TheForgottenKing
                                        • Apr 2021
                                        • 16
                                        1920x1080, I'll try a usb movie once I reassemble the TV.
                                        • reessi
                                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                          by reessi
                                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                          They are black on the right and gradually fade to nothing on the far left.
                                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                                          They flicker continuously very fast! With a slight pause milli-second every second.
                                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                          I tested each half by removing the first the left flex from...
                                          06-03-2025, 09:58 AM
                                        • SmartSarah
                                          Sharp LC70LE747 Flickering - darkening gradually to the right side
                                          by SmartSarah
                                          Dear,
                                          I can not pinpoint the following problem on my Sharp TV LC70LE747E.
                                          While the left side of the screen is not affected at all the right side of the screen gradually fades to a kind of dark. I can best describe this darkness like a totally worn out CRT display or a gamma correction totally out of range. This darkness flickers like a flame, a dark one tough.
                                          Sometimes when I restart the TV it disappears for a while.
                                          The problem worsened over time the last few months.
                                          I've replaced the t-con module without success. The problem remains.
                                          05-23-2022, 01:00 PM
                                        • fanaticgames
                                          Philips 43PUS6703/12 screen flickering intermittent
                                          by fanaticgames
                                          Hi guys,
                                          I have this philips with this defect, I tried cleaning the flats of the t con but nothing changes, is the screen the problem??
                                          https://streamable.com/0zl6y3
                                          01-05-2023, 09:19 AM
                                        • DrvLikHell
                                          Fixing an I-Inc IF281D for the 3rd time, now with added flickering!
                                          by DrvLikHell
                                          Hello everybody! It's been nine years and I'm back again with the same monitor that several people here helped me fix back then. The first time, I replaced two caps as was recommended here and the original problem was solved. Then it started acting up a few years later and I came back for a parts list and replaced a few more caps (I didn't make a post about that and don't remember which ones), and again the problem was solved. This time, however, I'm not sure if it's caps.
                                          The monitor stays on but certain colors will flicker. Generally it's darker colors like dark greys or dark blues,...
                                          07-05-2024, 02:54 AM
                                        • protocold
                                          MacBook Pro 15" 2010 820-2850 intermittent charging
                                          by protocold
                                          I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                                          I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                                          when it is not intermittent:
                                          PPVBAT_G3H_CHGR_R is 12.07v
                                          when it is intermittent:
                                          When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                                          when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                                          data line on the battery...
                                          07-25-2025, 08:18 PM
