LG26LD350 dead
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    LG26LD350 dead
    Hello folks how are you all ?
    I have this LG26LD350 that had a blown power supply the psu is the LGP26-10p. In fact i found a blown (cracked) ic500 ice3b0365j , shorted zd501 1n5230 (4.7V 500mw) , and open f501 3.15A.
    I replaced them all but culd not find ice3b0365j so i used an ice 2b365.
    I get no voltages from the psu whatsoever. Ive checked all components appart from the smd's and seem to be ok.
    On the main filter capacitor C607 i get 317V not the 380 i would expect to see. could it be that the ice 2b365 is not working or is not suitable replacement ?
    I dont know where to look next. Any ideas ?
    Thanks !
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Re: LG26LD350 dead
    Anything ?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      Re: LG26LD350 dead
      Ice3B0365J - Vcc 10.6V to 26V, 650V, Rdson 6.35 ohms, 22W @ 230V, 10W @ 85V to 265V, 67Khz
      Ice2B365 - Vcc 8.5v to 21V, 650V, Rdson 0.45 ohms, 67W @ 230V, 45W @ 85V to 265V, 67Khz
      I wouldn't think they are interchangeable due to the power dissipation and series resistance.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Re: LG26LD350 dead
        Having thought about this again, ignore my earlier reply.
        My current thought is that the Rdson is a lot higher for the 3B0365 than for the 2B365 and maybe that's what is causing the issue. Maybe unbalancing the Isense feedback to the IC.
        • R_J
          • 9624
          Re: LG26LD350 dead
          The ic may or may not work as a replacement, Did you check if the current sense resistor R503, (zd501) is across the resistor.
          What is the VCC voltage on the ic?
          This ic is for the 3.5v standby voltage only.
          • HellasTechn1
            • Sep 2015
            • 176
            • Greece
            Re: LG26LD350 dead
            I am not sure what you mean...
            • HellasTechn1
              • Sep 2015
              • 176
              • Greece
              Re: LG26LD350 dead
              Ok i understad now. The IC is not getting any supply voltage. The current sense resistor reads 1.3Ohms which is normal.
              between the supply pins of the 2b365 (pin 8 GND, pin 7 VCC) there is a Zener diode (ZD502) which is 1n5252 24V zener.
              I think i have just located a potential problem. The zener is a 24V one while the VCC of 2b365 ranges from 8.5 to 21V. Could it be that it is damaged? Tracker image does not suggest a short circuit between the VCC and GND pins of the IC though.
              It is most likely that this issue is irrelevant to the fact that the ic is not getting VCC.
              I have tracked the supply rail back to t501 transformer through D502 and found no fault. Also the transformer windings seem to be ok (continuity tested).
              • R_J
                • 9624
                Re: LG26LD350 dead
                After a closer the at the ic, the 2B365 will not work, it does not have the vcc startup cell that is in the 3B365.
                The ICE3B365 has an internal startup cell that (internally) takes the drain voltage and produces the vcc startup voltage. This startup cell is missing in the ice2b365 ic.
                • double_DD
                  How can I be sure that my EC chip is dead?
                  by double_DD
                  As the title suggests, how can I be sure that my EC chip is really dead?
                  I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                  Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                  03-12-2025, 07:47 AM
                • disorder
                  ps5 edm-033 dead after hdmi/usb ports destroyed
                  by disorder
                  hello guys,
                  i need help to repair a edm-033 ps2
                  history : as always hdmi port and usb ports destroyed after unplugged
                  after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                  so i changed it
                  now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                  but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                  i don't see any projection of liquid metal on pcb.
                  01-14-2025, 12:48 PM
                • zunasthegreat
                  Chieftec GPS-450-AA with dead 20N60C3
                  by zunasthegreat
                  Hello everyone hope all doing well!
                  I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                  09-01-2024, 07:12 PM
                • Beton
                  Finding a dead short component
                  by Beton
                  Hi guys!
                  I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                  So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                  I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                  I have a bench PSU and if I try to inject voltage the voltage...
                  12-10-2021, 01:05 PM
                • FiguringITout
                  MSI Raider GE75 - Not posting, probable dead CPU
                  by FiguringITout
                  Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                  Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                  07-25-2024, 07:27 AM
