What causes these ribbon cables to burn up?
  • MikeRWK
    • Jun 2017
    • 121
    Notice they have what looks like a notch in each side, that's where they burnt. Is it a bad tcon ground or bad panel ground?
  • R_J
    • 9624
    Re: What causes these ribbon cables to burn up?
    It is very likley the panel (circuit board attached to the panel) that has a short, sometimes it is a shorted chip cap, but could also be due to cleaning liquid running down the front of the panel shorting out components.
    • MikeRWK
      • Jun 2017
      • 121
      Thanks for the answer
      • RDC55
        • Dec 2017
        • 180
        Likely what R_J said, but do you have the mounting screws in the TCON to ensure it is properly grounded?
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • zesko
          xps 9520 ribbon cable
          by zesko
          I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
          There is 2 models, idk which one is needed on my laptop.
          0xkvng
          00vpr2
          Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
          Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
          thanks...
          10-23-2025, 05:03 PM
        • howardc64
          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
          by howardc64
          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
          • Backlight on, no image
          • Disconnect right buffer board (view from front), left side display comes on
          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
          • Buffer board is pretty simple
          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
          07-11-2025, 04:04 PM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • alro7779
          Samsung UN55MU6103F video problem; has colored stripes on the display
          by alro7779
          Hello, everyone!
          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
          09-27-2025, 11:29 PM
