Blaupunkt B32A122T - no power
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Blaupunkt B32A122T - no power
    Originally posted by chabregas2k
    I tested the mosfet with the multimeter.. the basic open close / charge discharge test.
    RB148 reads 0.4Ohm
    Mosfet is MDF7N60B
    When taking the pics for you, i found RB108 to be "funny looking" so i measured it to 8.7kohm (onboard). Should read 22 Ohm am i right??
    Thanks for all your time once again!
    If RB108 has 223 written on it then it would be 22K ohms. However if it is 222 then it would be 2K2 ohms. Can't quite read what is on the resistor.
    What resistance does RB147 have.
    • chabregas2k
      • May 2021
      • 24
      • Portugal
      Originally posted by dick_barton
      What is the diode number written on it?
      SR3200 - Shorted original one.
      Ive got here SF50GG and SB5100. Any of these are aceptable replacements?
      Otherwise ill have to order... or struggle with the donor pile
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The SR3200 is 200V @ 3A so it looks like the SF50GG (400V @ 5A) should work.
        • chabregas2k
          • May 2021
          • 24
          • Portugal
          Heres something new....
          good thing i have a picture of the "before"
          this happened as soon as i flipped the power switch.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            CB101 appears to have vapourized. What other component burnt up?
            What is the part number for UB101
            • chabregas2k
              • May 2021
              • 24
              • Portugal
              #26
              Mdp 36r da
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                The MDP36R looks as though it may be an LD7536RGL which is a PWM controller IC
                I would suspect it has been damaged so I would also check the mosfet to see if it's short circuit.
                • cheeky2
                  • Dec 2012
                  • 339
                  #28
                  I would also check the resistor RB148 circled in white in attached picture as look vaporised in the middle
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    Also clean the area up with some alcohol and some cotton buds to remove the carbon debris.
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
