JVC LT50C-550 backlight issue
  • Bloopeta
    • Jun 2018
    • 526
    • United Kingdom
    I have a JVC LT50C-550
    When switched on, it flashes on for a brief second as if backlights are at fault. I have stripped down and tested LEDs and all are fine, can illuminate the array no problem with tester.
    All caps look ok by sight.
    Any help as where to go next grately appreciated
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: JVC LT50C-550 backlight issue
    Although the tester is useful it does not pass a high enough current to fully test the strips.
    They may well show good at 30 - 40mA testing current, but fail when running at higher currents.
    I can't quite make it out but does it say 800mA led current on the power supply board?
    • Bloopeta
      • Jun 2018
      • 526
      • United Kingdom
      It does m8 yes, 800ma
      • neilc6
        • Nov 2015
        • 1550
        Remove the panel and record the flash. Go frame by frame to see which strips are out. I would just replace all the strips with new.
        • Cornito
          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
          by Cornito
          Hello Team,
          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
          08-08-2024, 08:09 AM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • Acnologia
          Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
          by Acnologia
          Hello to all members of badcaps.
          Another brainstorming that i have been messing with for months as a side project.
          Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
          I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
          Step 1.
          Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
          Machine > Doesn't give display it's really dim.
          Step 2.
          Use the same...
          11-05-2025, 04:02 AM
        • Cornito
          TCL 65C715 backlight issue
          by Cornito
          Hello team,
          I'm back with another topic.
          It's a 65C715 TCL tv with backlight issue.
          But the problem is a bit strange.
          When I took this tv from the marketplace backlight didn't work but picture was ok.
          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
          Putting all back together the tv worked fine for weeks. => Contact issue??
          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
          06-09-2024, 02:24 AM
        • shellybelly
          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
          by shellybelly
          Back Story
          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
          08-27-2023, 10:40 PM
