LG LED TV Blink Error Codes
  • ikmpch
    • Jul 2020
    • 22
    I would appreciate if any knowledge member can provide some insight into LG LED TV blinking light error codes. That is the number of time the red LED blinks and which part of the TV is responsible for that code. I believe this information will help many hobbyists like me. Thanks.
  • neilc6
    • Nov 2015
    • 1550
    Re: LG LED TV Blink Error Codes
    LG TVs don't have blink codes. Only Panasonic, Sony and the older Sharps (non-Hisense). Both LG and Samsung front LEDs may blink while booting. LG UH series may blink after protection shutdown from bad LEDS.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      My sister upstairs, has an LG UH6100 series with bad LEDs, TMK!
      Still works, but the writing is thoroughly on the wall!
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • ikmpch
        • Jul 2020
        • 22
        Thanks for your reply nielc6. LG LED TV 55LW5000 has its red light slowly blink two times before turning off at TV plug in. TV does not start. If it is not error code then it seems a protective shutdown. What part of the TV is defective when red light blinks twice and TV does not start up. Any thoughts? (EEPROM, Main Board etc.?)
        • neilc6
          • Nov 2015
          • 1550
          LE, LV, LW and LS series LG TVs all have main board BGA failures. You can search your model for repair services on ebay. You can also try heating the processor with a hair dryer before plugging it in.
          • michalk3777@gmail.com
            Sharp Hisense - LC-65N7004U Error codes
            by michalk3777@gmail.com
            Hello, looking for a list of error codes for this TV. made in 2020, its manufactured by Hisense under Sharp brand. No clicks, black screen, no sound, power light is on solid. When I press power, it blinks 5 normal blinks and 1 short. and nothing happens.
            Anybody has a list of error codes that might apply to this TV? I have not opened it yet.
            Regards,...
            12-15-2024, 09:20 PM
          • pixelcap
            Pioneer Kuro Pro 111FD 8 red blink error
            by pixelcap
            Pioneer Kuro Pro 111FD 8 blink red LED.
            I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
            So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
            based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
            10-06-2024, 11:26 PM
          • Sus256
            HISENSE 65E7KQ PRO - no boot
            by Sus256
            Hi all!
            HISENSE 65E7KQ PRO
            RSAG7.820.13512 - chassis
            MT9618BAATAB - cpu
            RSAG7.820.12059 - power
            HD650Y3U77 - panel
            KLM8G1GETF - emmc
            The TV does not turn on, the standby indicator is on. All voltages are present.
            Emms is dead. Not readable, not detected.
            Replaced emmc.
            But with another dump there is no launch
            Terminal log
            UART
            AC_ON
            RPMB key is not yet programmed
            HASH1_VERSION=0x00000000 64bit
            E-B
            FDE enabled
            layout pattern onebin by SAR7,0...
            06-01-2025, 02:11 AM
          • nervx
            Panasonic TH-42PZ800 8-blink error mystery
            by nervx
            Years ago my tv gave a 7 blink code which turned into 8 during diagnosis. I had ordered a replacement ss board but somehow the tv started working again and i never used the board. Now a week ago my tv flickered and shut off at random and gave the 8 blink error code. The same issue it had all those years ago. The only difference this time is that over the last few months there has been some purple and green tinge that comes and goes in more solid colors such as white.
            Anyway i checked all the screws and replaced the ss board with a known good one and still got 8 blinks. I saw a...
            04-08-2022, 05:19 AM
          • sushilachuthan
            APC UPS error P13
            by sushilachuthan
            one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
            the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
            The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
            We replaced the SCR with new device,, but the device is not power on as expected.
            Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
            09-26-2025, 09:00 AM
