LG Model 55LW5000 Power Up Issue
  • ikmpch
    • Jul 2020
    • 22
    I am trying to repair LG TV Model 55LW5000.
    At plug in, the red LED blinks twice and then Blue LED lights for a second and then its all dead. Opened the back cover and measured the voltages at the power connector pins with all cables attached. Here are the results:
    At pin 1 = 3.3V (PS-ON)
    At pins 2,3,4 = 24V
    At pins 9,10,11,12 = 3.5V (ST-BY)
    At Pins 17,19,21 = 12V
    At pin 18 = 0V (DRV-ON)
    Main CAPS (4 of them) = 396V
    Fuse F100= 120VAC, F101= 395VDC, F501=395VDC
    All most all voltages present but the set does not go into standby? It looks the set is in 'RUN' mode but only dead!
    Tests:
    1- Disconnected Power supply connector. Plugged in the TV and measured ST-BY voltage on pins 9,10,11,12 = 3.5volts.
    2. Jumped pin 9 to pin 1. Got PS-ON=3.3. Pins 17/19/21 = 12V and pins 2,3,4 = 24V. Also got 55V on backlight connectors.
    3. Put in a second jumper from ST-BY to pin 18 (DRV-ON) and the backlight lit up. It suggests that individually the P/S board and inverter circuits are working.
    4. T-CON is missing 12V input
    Why DRV-ON is 0? No Supply to Inverter. What is reason that set goes into such a mode with just plug in and does not even go into standby?
    Is it a firmware issue (bad EEPROM)?
    Is it a MICOM (micro controller issue)? There is a reset option on the mainboard. How can it be reset?
    There is an ERR OUT pin (pin 24) on PS connector. What is the purpose of it? Is it possible it is shutting the power supply with this two blink code.
    Your input will be greatly appreciated. Thanks.
  • alfatv
    • Sep 2020
    • 353
    Re: LG Model 55LW5000 Power Up Issue
    Haven't seen this model, but on LW5700 the typical failure is solder joint cracks on main board BGA (under heatsink).
    • neilc6
      • Nov 2015
      • 1550
      Yes LE, LV, LW and LS series all have BGA issues with the main board. You can test by heating it up with a hair dryer before plugging in. Search for repair services on ebay.
      • ikmpch
        • Jul 2020
        • 22
        Thanks guys. My plan of action:
        1. Test the ICs that supply 1.5, 3.3, 1.26 & 2.5V regulated power on the main board.
        2. Cut the ERR_OUT wire and see what impact it has on the TV power up.
        3. Heat all 4 BGA chips on the main board.
        I shall post results of my tests.
        • ikmpch
          • Jul 2020
          • 22
          Update:
          I checked various voltage regulator ICs on the main board and some were dead and others had .05 volts or so.
          I cut the ERR_OUT wire and it did not help.
          I heated all 4 BGA chips. The TV did not turn on. Some of the voltage regulators did show some life. Heating/reflow using flux did not help. The owner had baked the board twice in the oven previously. Giving the TV back to its owner for disposal.
          • thstuff
            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
            by thstuff
            A) TV initially dead
            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
            12-26-2024, 09:10 PM
          • rounin
            MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
            by rounin
            I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
            🛠 Original Issue
            The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
            ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
            04-19-2025, 01:18 AM
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • shahnld
            Lenovo legion 5 pro startup issue
            by shahnld
            Good day Experts
            I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
            A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
            And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
            08-24-2025, 12:31 PM
          • ahmarzo
            Acer laptop battery draining issue
            by ahmarzo
            Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
            Help me to diagnose this issue as there is no shortage in the inputs MOSFET
            08-02-2025, 06:39 AM
