Samsung ue46f8000st hdmi not working
  • alltvrepairs
    • Jan 2014
    • 245
    • Malta
    I have 2 main boards bn94-06199t both hdmi not working.
    I have factory reset, EDID rewrite from service menu, updated doftware etc to no avail.
    1 board senses hdmi inputs but still black screen and says no signal.
    Trying my luck if any guru here has some feedback.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Samsung ue46f8000st hdmi not working
    Have you tried other HDMI leads or source. Seems odd that 2 boards have the same issue.
    Do the HDMI show up on the AV select menu or are they missing or greyed out?
    • alltvrepairs
      • Jan 2014
      • 245
      • Malta
      Yes tried different sources abd different leads. 1 board sees the hdmi when connected in source list but black oucture and saysno signal. The other doesn't notice when plugging hdmi. Usb and internet wirk fine.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Have you tried the Upgrade File(USB type) ver 1136.0 727.42 MB Dec 06. 2019 Windows
        https://www.samsung.com/uk/support/m...E46F8000STXXH/
        • CapLeaker
          Leaking Member
          • 8325
          Or the HDMI IC is bad.
          • mlemon
            • Feb 2021
            • 34
            You may find this link very helpful. It's not a samsung TV but Visio but the principle may be same:
            https://www.youtube.com/watch?v=8U-01HUx0qY
            • alltvrepairs
              • Jan 2014
              • 245
              • Malta
              Tks All. I am suspecting the HDMI IC SIL9687ACNUC. Unfortunately I do not have the tools to change. I have a temperature controlled heat gun and changed several HDMI ICs that requires soldering, but not these types of ICs.
              Link to IC
              • ivtec
                • Dec 2008
                • 1967
                Link to IC
                Normally HDMI failure is because people are carless and do not know that connecting and disconnecting Hdmi cables with source on and Tv on will end up in Hdmi IC switches failure, my Nephews use to disconnect and connect their cable from PlayStation with tv and PlayStation on and ended up with all Hdmi inputs broke .
                • grimacelord
                  Samsung UN50MU6070FXZA - HDMI Ports Not Working
                  by grimacelord
                  Hello. Samsung UN50MU6070FXZA here with both HDMI ports non-working. I have already verified multiple sources and multiple cables to ensure it isn't something simple like that as well as resets and software updates.
                  I took the mainboard out and gave it a look. Nothing looks bad or burned. All of the HDMI pins are nice, none are broken at their pads either.
                  Following the traces, it looks like both HDMI ports trace back to the main CPU which does seem to get hotter than I think it should despite it's (rather poor) heatsink.
                  Since the HDMI controller appears...
                  11-03-2021, 03:10 PM
                • DynaxSC
                  ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                  by DynaxSC
                  I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                  Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                  Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                  The behaviour is also really very strange, i.e.:
                  • The disk shows always up in BIOS - so it is recognized, so far so good
                  • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                  02-23-2025, 01:33 PM
                • hinisa
                  GTX 750 HDMI output not working
                  by hinisa
                  Hi
                  I have an GTX750-FML-1GD5 with a non-working HDMI port and I'd like to figure out what's the cause and if it's easily repairable.
                  GPU is working fine. VGA and DVI-D ports are also working just fine. But whatever monitor or TV I plug into the HDMI port, it isn't even recognized, let alone giving a display.
                  I took a glance at the HDMI port and couldn't see any obviously broken parts.
                  I've also read on various forums that some firmware versions have non-working hdmi, so I flashed dozen or so different VBIOS ROMs that I acquired from techpowerup...
                  12-05-2021, 07:58 AM
                  09-07-2024, 05:50 AM
                • jayakumar
                  dell 5490 la-f401p no display ( in HDMI out working )
                  by jayakumar
                  I have dell 5490 la-f401p problem: no display ( in HDMI out working )
                  changed working bios ,working screen ,cable
                  Please help me to resolve the issue
                  i have more then 7 laptop's having the issue
                  08-06-2024, 10:03 PM
