TV fixed it self?..please read
  • RicB
    • Mar 2010
    • 19
    i posted about my 2004 NEC PX42VP4A plasma tv, having an issue with turning off as soon as a signal was put to it...well an hour ago i decided to put the PSU back in and test the 15 pin computer hook which i thought i had tested but did not..long story short the computer booted up and thats when i saw kubuntu splash on the screen...and it stayed on : next I plugged in my DVD (RGB component cables) player and it has been playing now for the last 20 mins I am at a loss as to how it fixed itself...i know sometimes that electronics can get..."confused" especially after a power dip/loss and this is my only guess as to what happened and me removing the PSU completely powered down the other 2 boards effectively rebooting them...anyone else ever have this happen? and what was the cause?
    thnx
  • PlainBill
    • Feb 2009
    • 7034
    Re: TV fixed it self?..please read
    thnx
    The logical assumption is that one or more of the 437490 solder joints has broken. Your handling has caused them to make contact again. Now you are going to ask "Which one?"
    DamnifIknow.
    PlainBill
    • RicB
      • Mar 2010
      • 19
      well if it is a solder joint then i know it has tobe on the PSU because that is the only thing i have handled, I think ill go buy a magnifine glass
      • RicB
        • Mar 2010
        • 19
        ok gents riddle me this...how can a tv not work (go to standby when signal is applied or lets stand for more than 2 mins) then have the PSU removed for almost 4 days then have the PSU put back in (with out any repairs) and have the tv work for almost the same amount of days?(tv is back to original problem) ... I cant get my head around this one...i know what bad solder is...i know what a bad cap looks like...I know how a failing cap can act (screen bowing in on the sides when tv starts) I know that some components work fine when there cold but after heating up can start to act up...but this problem is something i have never heard of or seen. the only correlation i can see is the time the PSU was out of the tv and time it was working for (4 days out , 3 days tv working).
        has anyone heard of anything like this??
        thnx for any help
        • tmwalsh
          • Jan 2009
          • 119
          FWIW, you could have a cracked trace on the PS board. Just recently had a cracked trace on the 'gun' board on a crt. Had to push on the back of the monitor case to get green to display. Found a minor crack...
          Surely the board got flexed at least a bit when you removed and reinstalled it, no?
          tom
          • seanc
            • Nov 2008
            • 1319
            Have you re-soldered all of the connectors and cables that hook up the power supply board?
            • weirdlookinguy
              • Sep 2007
              • 1638
              Try resoldering every connector, everything on a heatsink, all coils, and anything that looks like it gets hot on the PSU.
              • RicB
                • Mar 2010
                • 19
                thnx guys for your responses , now there is a new development...the regular composite (yellow rca video) turns the tv off as described when signal hits it...but the RGB component works (which it did not do originally) . There is a weird green hue that shows up during some scenes in a movie...mostly during blue sky scenes, i thought i read some where that bad caps on the PSU can cause this kind of problem.
                Do you think the input board is bad as well? or could it have been the problem all along? do i still replace all the caps on the PSU or start looking at the input board?...this is getting confusing
                thnx again for any help
                • ausheaven
                  • 16
                  As some has suggested, it is possible that there is bad soldering. One possible problem is heat. Some component is about to fail. As you leave the TV on heat gradually builts up take the soul out of it performance but not enough to break it down. This will be your most difficulty task to find.
                  Your initialy description point towards this direction.
                  If you suspect bad caps is the problem try this first. Caps are cheap.
                  If you are handy with a soldering iron replace the caps (eectrolytic only) one at a time, if after several go you have a fix then run it for a few hours and see if the problem comes back, if it is all OK then you have found the problem. If after replacing every caps and you still have a problem then you have to look elsewhere.
                  The colour turning green indicate that there is a problem elsewhere.
                  • RicB
                    • Mar 2010
                    • 19
                    thnx for your reply, i did some research and found out that these units run hot I can smell the heat from 5 ft away, when the unit has been on for an hour I hear what i can only describe as a tiny electric motor touching a bit of metal....it is coming from the scan board I know there is no motor back there so I am sure there is something about to die I
                    will try the caps on the PSU and look for broken trace...but after that i am not sure the tv is worth any more investment of time or money
                    • Wizard
                      • Mar 2008
                      • 2296
                      Reason I do not like a TV that reanimates themselves is intermittent components or bad solder jonts. I just had caught one (old samsung 42" plasma units) and warned my coworker to pull power supply and check. These SMPS boards are 1 layer type. Not double sided.
                      Cheers, Wizard
                      • howardc64
                        Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                        by howardc64
                        TV was fixed just after removing Samsung's rear snap cover.
                        This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                        Maybe PSU->backlight connector didn't have a good contact?...
                        07-23-2025, 12:34 AM
                      • dfear
                        ASUS Vivobook X1500e - no image and no backlight. Can this be fixed?
                        by dfear
                        ASUS Vivobook X1500e came in with no image and no backlight.
                        Motherboard is: x415ea.
                        Current knowledge/observations:
                        RAM, LCD & LID sensor = oood.
                        LCD connector - AC_BAT_SYS_ is present.
                        D4501 schottky diode - LCD_BACKOFF# is always 3.3V, whether the lid is closed or not.
                        CPU thermal signature seems normal.
                        Laptop boots and outputs to HDMI.
                        Is part of the CPU bad or can this be fixed?
                        10-14-2025, 04:02 AM
                      • howardc64
                        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                        by howardc64
                        Failure Symptom
                        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                        Where is the short?
                        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                        05-27-2025, 02:56 PM
                      • howardc64
                        LG 55UN7000PUA fixed with just dis/reassembly
                        by howardc64
                        TV runs, backlight on, have sound and no image (dark grey/blue/black LCD)
                        Disconnected right (looking from rear of TV) tcon-buffer board cable, LCD left half displays.
                        No shorts on right buffer board.
                        Started masking tcon-buffer board signals... (connection #1 in main board pic) about 20+ pins from top of connector... LCD fully displays with some anomalies.
                        Gradually reduced # of masking signals... eventually down to 1. Removed that... LCD works perfectly.
                        No obvious damage on right buffer board 3x COF to the panel like another 43" LG fixed ( link ) with...
                        09-19-2024, 11:16 PM
                      • marce002
                        Can you suggest me how to variable output this 42v fixed
                        by marce002
                        Hello
                        I have this board working fine designed to 42v fixed output using lm324n chip and i really need to make adjustable output (ideal if Vol and Current with 2 pots but at least only Vol).... i was trying to do it with datasheet and several diagrams but could not
                        the pins 1 2 and 3 are unconnected so it is using only 3 op amps in the chip.... How do you think I can mod it?
                        or any hint for an schematic similar.. thks in advance...
                        03-05-2024, 12:05 PM
