Samsung UN70NU6070F power cycle.
  • Neednos
    • May 2021
    • 12
    • Quebec
    http://imgur.com/gallery/iqa5KiY
    Samsung UN70NU6070F
    Picked this tv up off marketplace for 50 Canadian coins.
    Old owners say it got darker and one day just died. If you plug it in it will power cycle non stop. I opened the tv up and if you unplug mb from power supply backlight will turn on and stay on. As soon as you plug in mb it will power cycle again.
    Next thing I tried was unplugging the long flat cable from bottom of tv. Doing this and waiting to plug back in will make it so that I can get a picture and sound.
    Next thing I tried was unplugging this long cable again and leaving unplugged. I was able to play audio with no picture.
    When it powers on it looks great, no weird lines or anything. If I can get it to stay on what a steal lol.
    What should I look for? Bad tcon board? Bad power supply? Bad mb? I'm more lost than ever
  • Neednos
    • May 2021
    • 12
    • Quebec
    Re: Samsung 70 inch power cycle.
    I can't seem to edit the title but if mod can add UN70NU6070F that would be great. I didn't see it in the rules until right now
    • Storyteller12
      • Jun 2020
      • 625
      Re: Samsung UN70NU6070F power cycle.
      Unplug the cable on the power supply to the main board and see if the backlights stay on when the tv is plugged in like that.
      If it does unplug tv and reconnect cable.
      This time undo the lvds cable going to the panel 1 at a time. And then both.
      Report results if the tv is still rebooting or stays on.
      Note the tv will show nothing when both lvds cables unplugged so watch the led light or the optical on the main board to see if it restarts.
      A lot of these NU series tv sets have bad leds. Usually it doesn’t cause the tv to reset though.
      If you have the Samsung logo visible when first powered on I would say the tcon is good.
      Could be panel fault or main board at that point
      • Neednos
        • May 2021
        • 12
        • Quebec
        A lot of these NU series tv sets have bad leds. Usually it doesn't cause the tv to reset though.
        If I unplug main board from power supply back lights stay on.
        If I unplug one or both of the lvds cables tv will boot and stay on
        If I plug the lvds cable back in while it's on tv will work perfectly. Until you turn it off or repower it. Then it will start power cycling if you try and turn it on again. I plugged in a Chromecast and was able to play an hour of video before I tried the power cycle.
        When on panel looks perfect.
        • Neednos
          • May 2021
          • 12
          • Quebec
          Here's a pic of the screen on. Hard to get a good pic with the display facedown.
          • mlemon
            • Feb 2021
            • 34
            Same here for my post, After posting it I wanted to edit the Title but was not able able and at some point I managed to but still shows the original title!
            • Neednos
              • May 2021
              • 12
              • Quebec
              So close!
              • Storyteller12
                • Jun 2020
                • 625
                Ok. That seems to narrow it down to the panel then. You can check the lcd board that the lvds cable connect to for bad smd capacitors.
                If nothing is shorted then only thing I can think is the panel is bad. Last resort is the tape method. Try taping off some pins and see if that works. YouTube it if your not sure to get an idea
                • Storyteller12
                  • Jun 2020
                  • 625
                  Also it’s not good to plug the lvds cables in while tv is powered on. You can esitlybahort something if the pins don’t line up perfect
                  • Neednos
                    • May 2021
                    • 12
                    • Quebec
                    Also it's not good to plug the lvds cables in while tv is powered on. You can esitlybahort something if the pins don't line up perfect
                    I will stop doing that then! I'll start looking at the bottom boards tonight for any bad caps. When you say it could be the screen is this something I am able to look at?
                    • Storyteller12
                      • Jun 2020
                      • 625
                      Unfortunately you cannot see anything with the screen. Just have to try taping off a few pins at a time and see. It’s a tedious trial and error kind of thing.
                      It’s kinda odd it worked fine after plugging in the cables when the tv is powered on. Usually if there is a short it would not work. It’s must bypass a check after startup or something.
                      • Neednos
                        • May 2021
                        • 12
                        • Quebec
                        Ya after its plugged back in it seems to work fine. So I should look for the pins labeled something like CLK cover them and trail and error uncover them one by one? I see on other videos they unplug one side of display and theyll get a half picture. For me it's nothing when I unplug either side and again when either side is plugged back in I get a full picture again.
                        Unfortunately you cannot see anything with the screen. Just have to try taping off a few pins at a time and see. It's a tedious trial and error kind of thing.
                        It's kinda odd it worked fine after plugging in the cables when the tv is powered on. Usually if there is a short it would not work. It's must bypass a check after startup or something.
                        • Storyteller12
                          • Jun 2020
                          • 625
                          Yes that’s pretty much how you go about it for the tape. I forgot this tv doesn’t have a separate tcon. It’s built into the main board I believe.
                          Not positive but that may be why you don’t see anything on half the screen with just one side plugged of the lvds plugged in.
                          • Storyteller12
                            • Jun 2020
                            • 625
                            Maybe someone else with more expertise on these types of boards could chime in and assist.
                            Unfortunately that’s all the knowledge I have to help without having the tv in front of me to test.
                            • Neednos
                              • May 2021
                              • 12
                              • Quebec
                              This is extremely helpful. I'll try tonight and report back!
                              Unfortunately that's all the knowledge I have to help without having the tv in front of me to test.
                              • Storyteller12
                                • Jun 2020
                                • 625
                                Ok. I think I got the answer for you. Came across this today. I was right on about the tape method if it’s the name problem.
                                It’s the top lvds on the main board. If you pull it up and the pins are facing you, cover pin 15-24 or 25 starting from the left with tape. Black electrical is best but scotch works.
                                Plug it back in and should work if it’s the same problem.
                                Let me know if it works for you. If so enjoy your new TV.
                                Last edited by Storyteller12; 05-10-2021, 07:26 PM. Reason: Wrong #. 24 was supposed to be 25
                                • Neednos
                                  • May 2021
                                  • 12
                                  • Quebec
                                  Wow is it ever hard to get tape in Ontario ATM. Damn lockdown. Now to deal with the problem of counting these pins. So small. I've attached a pic to make sure we are on the same page.
                                  So you think this is a mb issue? I had actually ordered a new board that shows up in about a week, if I switch it out we should be good? I want to try the tape too as I want to be able to say I got this working without tossing new parts at it
                                  Ok. I think I got the answer for you. Came across this today. I was right on about the tape method if it's the name problem.
                                  It's the top lvds on the main board. If you pull it up and the pins are facing you, cover pin 15-24 or 25 starting from the left with tape. Black electrical is best but scotch works.
                                  Plug it back in and should work if it's the same problem.
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    Yes that’s the lvds cable. Unfortunately I believe it’s the panel not the main board. The panel is shorted on the inside somewhere
                                    • Neednos
                                      • May 2021
                                      • 12
                                      • Quebec
                                      Didn't mean to post the same thing twice..wanted to ask if this is repeated the same way on the other cable? If I might have to try this on both sides?
                                      What do these pins do? Are these the clock pins I was reading about
                                      • Storyteller12
                                        • Jun 2020
                                        • 625
                                        Just the 1 cable. Not both
                                        And yes, your just blocking the signal with the tape
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • mrtek
                                          Samsung UN43NU6950FXZA No power
                                          by mrtek
                                          Hi
                                          Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                          Main fuse = OK
                                          Back light LED = OK. Power them with aux power source
                                          LED output = OK 156V
                                          I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                          Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                          07-20-2025, 08:06 PM
