LG 49UH668V Blank screen
  • Runlinc
    • Apr 2021
    • 28
    • England
    Tv backlights not coming on:-
    Power on - Standby red light on (red)
    Press start button - Red standby light flashes 3 times then goes off. No backlights on at anytime during start up - no picture on screen with backlights off. I have checked all backlights in situ using 6v supply across test points on backlight strip, all light up.
    Power Supply voltages at Led plug and P201 plug when connected to main board.
    Stand by - Led + 59.8v P201 — MS 0v P-Dim1 1.9v
    Led - 40.6v. GND 0v GND. 0v
    Led + 59.8v (13.2v) 7.8v (13.2v) 7.8v
    Led - 41.6v (13.2v) 7.8v (13.2v) 7.8v
    GND 0v (13.2v) 7.8v
    PWR-ON 0v P-Dim2 1.9v
    Power on Led + 87.3v P201 — MS 0v P-Dim1 0v
    Led - 66.9v GND 0v GND 0v
    Led + 87.3v (13.2v) 13.1v (13.2v) 13.1v
    Led - 70.0v (13.2v) 13.1v (13.2v) 13.1v
    GND 0v (13.2v) 13.1v
    PWR-ON 3.3v P-Dim2 0v
    The voltage rise at the Led is smooth and stable. I cannot see anything obviously wrong on the boards. Please see attached photos.
  • alfatv
    • Sep 2020
    • 353
    Re: LG 49UH668V Blank screen
    You have to explain better what those numbers mean.
    And why GND is not always zero, where do you connect negative terminal of multimeter?
    • Runlinc
      • Apr 2021
      • 28
      • England
      Thanks for your reply.
      When I have uploaded it has condensed all the figures together without any spacing so I will try again.
      All readings are with negative probe ground on the chassis.
      I have annotated the photos with the voltage readings at Standby and after switching the set on. Hope this is ok.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        I'm not sure what MS is but it could be the backlight control signal input.
        Do the backlights come on if you disconnect the mainboard and power up?
        • Runlinc
          • Apr 2021
          • 28
          • England
          I cannot find out what MS is either.
          If I disconnect the mainboard and just run the power supply the backlights don’t come on.
          With the main board connected there is 3.3v at PWR-ON.
          I checked the voltage at the LED plug on the PS board during switching on and there is no voltage surge, only a stable rise to 87v
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            What is the power supply board numbers?
            Edit.
            I've just noticed the numbers are available from your photos in post #1
            I believe the MS is the backlight on signal but I would wait to see what others think.
            • Diah
              • Feb 2013
              • 6614
              yours photo https://www.badcaps.net/forum/attach...7&d=1618309849
              you have 2 groups LED backlights, each groups had same amount of LED units, LED- as your measurements at one groups had different of (-4V = 1 LED units defect / short / Open currents forward ziner diode )
              the way you tested LED BL are wrong. because each LED units had build in ziner diode for currents forward, which only with Digital meter Diode option to exam it.
              • Runlinc
                • Apr 2021
                • 28
                • England
                Thank you for your reply.
                How would I be able to isolate which led's are failing with a multimeter ?
                • Diah
                  • Feb 2013
                  • 6614
                  1- if you take the screen out, you still can power on the TV and you will see at start very dim fast the led will come on.. you may see which on will be off or...
                  2- with digital meter at diode mode. each led units if you test it will lit on dim and if you reverse the probe - + you will have ziner diode reading between 0.76 - 0.54 . open ziner will read nothings. short ziner will you have 0 with beep tone.
                  • alfatv
                    • Sep 2020
                    • 353
                    Is backlight flashing at all during power-up?
                    You may need to unplug TV for 1 hour or so first.
                    And measure the voltages between LED+ and LED- while powering on. See if there is voltage spike.
                    • Runlinc
                      • Apr 2021
                      • 28
                      • England
                      Took out the screen & diffusers - power on tv - no backlights flashed or lit up.
                      Isolated each Led rail.
                      Multimeter on diode setting - 17 of the 32 led's lit up, multimeter reading 1
                      The 15 Led's that didn't light up had multimeter readings of between .2 & 1.8 and the same readings reversing the probes.
                      Measuring the test points at the end of the strips the reading was .725 on all 4 strips.
                      Hope this makes sense.
                      Thanks for all your help.
                        • 12332
                        • U.S.
                        Pretty sure that's bad backlights, best policy is to replace all strips.
                        • Runlinc
                          • Apr 2021
                          • 28
                          • England
                          Changing all the backlights is not an economically viable for me I'm afraid.
                          Is there any way to replace individual LED's as these appear much smaller than any others I have seen. The light strips are 6916L-2453A
                          I would like proof the other parts of the set are ok, before I buy a full set of backlights
                          Many thanks for your help
                          • Diah
                            • Feb 2013
                            • 6614
                            you are still have error / wrong measurements. this cant be 15 LEDs get defect at once.
                            upload photo on the whole back of the set showing all boards how they connected together.
                            upload high resolution photos on the strips close to the sockets and to one of the LED to see the printed line on the strings how many you have.
                            • neilc6
                              • Nov 2015
                              • 1550
                              Do you have 4 rows of strips? These are the style that also turn blue if you run them at max and super tiny. They are only $20 - $30 USD on Aliexpress and you may find similar pricing on ebay.
                              If backlights don't come on or flash, they are your first suspect.
                              • Runlinc
                                • Apr 2021
                                • 28
                                • England
                                Photos attached as requested - LED's are 1mm square and show a blue light.
                                4 rows of 8 led's.
                                Hope photos are ok
                                • Diah
                                  • Feb 2013
                                  • 6614
                                  i can see you have 1 LED unit remarked with X didn't work..!!! i would suggest you to follow neilc6 found on aliexpress to replace all at once.
                                  • Runlinc
                                    • Apr 2021
                                    • 28
                                    • England
                                    Aliexpress has an 88% bad rating on Trustpilot in the UK !!!!!!!!
                                    • Diah
                                      • Feb 2013
                                      • 6614
                                      all what you find on Ebay are bought via Aliexpress / Alibaba then sold in high price... only Chinese produce them, if you still want to think on this negative rate then use candle without smoke 2 will be enough behind the screen and enjoy watching TV ..LOL
                                        • 12332
                                        • U.S.
                                        • hasel17
                                          CH341a can erase and read but can't write and blank check
                                          by hasel17
                                          So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
                                          Code:
                                          Checking for blank...
                                          (Press
                                          10-26-2023, 06:20 AM
                                        • kotel studios
                                          Funai 32FL553P/10 - squealing from PSU, dies after 10 seconds, blank screen after logo, bootloops
                                          by kotel studios
                                          Found an Funai 32FL553P/10 TV on sale for cheap listed as broken, so I decided to give a shot at reparing this.
                                          State I got it in:
                                          Squealing from the PSU
                                          After logo I get a blank screen
                                          After 10 seconds of having a blank display w/ backlight the TV dies
                                          Give it 7-10ish seconds again and it starts to bootloop.
                                          What I did so far:
                                          Replaced all the caps on the PSU (apart from primaries, they were fine and none at hand)
                                          Checked all voltage rails:
                                          5VSB - 4.8V
                                          AMP+13V - 14.4V
                                          13V - 12.98V (in manual 12V)...
                                          09-21-2025, 02:00 AM
                                        • RetroComputingGrotto
                                          Hanns.G Hi221 Monitor - Works For A Second & Then Blank Display
                                          by RetroComputingGrotto
                                          I've got a Hanns.G Hi221 Monitor that works for a moment and then the display goes off but the power LED indicator remains on. If you power it off and back on again it does the same thing, it comes on and then the display goes blank. From a cold start it takes 10 seconds or so before the display goes blank but if you turn it off and then back on again after it already being on it goes blank a lot quicker so I'm assuming something is getting hot which is causing the display to go off.
                                          I've uploaded a video of it happening on YouTube:
                                          I've taken the monitor...
                                          01-11-2024, 05:37 AM
                                        • Chrissygizmo
                                          Panasonic TX-48CX350B backlights but white screen , blank screen
                                          by Chrissygizmo
                                          Hi all, I’ve got a problem I hope someone can help me fixi.
                                          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                          01-11-2025, 03:18 PM
                                        • Spoonicks
                                          ASUS VH238T blank screen with backlight
                                          by Spoonicks
                                          I am having a problem with a ASUS VH238T.
                                          The monitor started by just going blank, but the integrated speakers, and the backlight worked. The OSD didn't pop up, neither did the messages of DVI No Signal, nor the Asus logo.
                                          Turning off the monitor, and turning it back on made no difference. But leaving the monitor off for a few hours returned the monitor back to normal. The problem will eventually return after a couple of hours.
                                          Today, it started exhibiting another symptom: the display started showing a white image, that didn't take the whole screen....
                                          07-04-2023, 01:29 PM
