LG 60PV450 - Replaced Z-Sus, now display has purple snow/fuzz
  • bmschiizz
    • Oct 2015
    • 22
    Hi There,
    If memory serves me right this set was totally dead when I acquired it. Replacing the z-sus brought it back to life but with some purple haziness across the whole panel.
    Vs and Va are within tolerance.
    By making some slight adjustments on the Y and Z boards I was able to make it better but still noticeable
    What are my steps to isolate/solve the problem.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: LG 60PV450 - Replaced Z-Sus, now display has purple snow/fuzz
    Eek! Looks like it's got '00s-style glue!
    (the dreaded brown stuff that's often seen on 2003 and 2004 equipment)
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • R_J
      • 9535
      What about the VSC voltage? what is it and does it match the panel sticker. Try adjusting the set_up & set_dn controls, Mark there positions with a felt marker before adjusting them.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Check the solder under the coils of the y and z sus boards. They crack over time and need to be re-soldered with lead solder.
          Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
          This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
          09-07-2024, 12:40 AM
        • gamartinelli
          Asus VG248QE won't power on / purple light
          by gamartinelli
          I have an Asus VG248QE that all suddenly stopped working. Everything was fine, I had my PC connected to the HDMI port and never had any issues. Then I decided to plug a laptop in the DisplayPort (USB-C to DP cable). It worked fine for a few hours, I left, at some point the monitor went to sleep mode and when I came back and moved the mouse monitor didn't wake up. The power button lights up in blue when the signal is good and amber when in sleep mode / no signal turned purple (first time I saw that). Did some research but couldn't find a way to bring my monitor back to life....
          09-29-2022, 04:15 PM
        • kilog
          Snow on screen and no start Do I have to replace my CF53-MK2
          by kilog
          Hello friends,
          Last week when I tryed to start my CF53-MK2 it just stop starting
          and when it starts it displays snow and dansing and coloured lines on the sreeen as you can see in the attached video.
          Some time it may show the startup Bios screen for a 3 to 10 seconds and then immediatly starts to disply snow and coloured lines.
          I tested the RAM it is correct.
          I tried to hook the machine on a HDMI screen, nothing.
          I am not sure that the computer goes far to be able to show anything on an additional monitor.
          Please I need your...
          09-27-2023, 08:00 AM
        • reessi
          LG Plasma ZSUS Flashing Screen, No Booting! - 50PB690V
          by reessi
          Replaced Zsus beginning of year as most transistors were short stopping tv powering up.
          Now screen flashes on off continually and ZSUS ticks. Looking like replacement maybe faulty or could something else cause it to shut down.
          If I remove both tabs from ZSUS to screen but keep all other connectors to ZSUS on then TV boots properly but screen very dark without ZSUS output, no ticking from ZSUS. So it only shuts down when under load from screen.
          If it is ZSUS then how to fault find, I already looked for shorts. No transistors shorted or caps and its...
          12-13-2017, 01:18 PM
        • Vlad713
          LG 55NANO913NA Purple / Pink Line / Spot
          by Vlad713
          I am struggling with an issue on my LG TV, as mentioned in the title - please see the attached photos.
          The display / panel has been replaced in March 2023, under warranty - right before expiring after 2 years of use - due to a bunch of dead pixels.
          Then in a few months the purple / pink line started showing up, however the LG service said that this is not covered by any warranty, anymore, since the original one has expired.
          Recently I have just asked a repair firm to have a look and they have said that the panel needs to be replaced,...
          01-11-2024, 04:14 AM
