i-joy firmware iled32shhpb01
  • spantor
    • Jan 2020
    • 46
    • spain
    Hello.
    It stays in the logo when I teach and then in black, no gun button and the command do not respond. I find out that it is firmware.
    Any charitable soul that can pass me firmware for spi flash of this iled32shhpb01 with cv309h-x board and hv320wx2-201 panel?
    Thanks in advance
  • spantor
    • Jan 2020
    • 46
    • spain
    Re: i-joy firmware iled32shhpb01
    Somebody could help me ? After a long time I still have not found this firmware
    • lotas
      • Jan 2016
      • 4905
      • Russia
      Post your non-working firmware here, I'll try to fix it.
      • spantor
        • Jan 2020
        • 46
        • spain
        Will be great.
        • lotas
          • Jan 2016
          • 4905
          • Russia
          Will be great.
          Try
          • spantor
            • Jan 2020
            • 46
            • spain
            Try
            Thank you very much for the file. Initially it works, the tv turns on. But some buttons on the remote control do not work, volume, channel change, menu etc. I really don't know if it's a remote control problem or it could be due to the file.
            What do you think ?
            • lotas
              • Jan 2016
              • 4905
              • Russia
              The remote control can be checked through the smartphone camera
              • spantor
                • Jan 2020
                • 46
                • spain
                In what way?
                • spantor
                  • Jan 2020
                  • 46
                  • spain
                  okay. I already found out the way. Actually the buttons do not emit a signal. You have done a great job with the file. I will try to repair the remote control
                  • lotas
                    • Jan 2016
                    • 4905
                    • Russia
                    Turn on the smartphone camera and point the remote at the rear camera and press the remote buttons and you will see the LED flashes on the screen, so you can check all the buttons.
                    • spantor
                      • Jan 2020
                      • 46
                      • spain
                      The command cannot be fixed. I'll order one or I'll put a universal remote. Thanks again for everything . Your help has helped me a lot
                      • lotas
                        • Jan 2016
                        • 4905
                        • Russia
                        Please, was glad to help.
                        • spantor
                          • Jan 2020
                          • 46
                          • spain
                          great man
                          • zklgfs
                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                            by zklgfs
                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                            08-11-2025, 02:14 PM
                          • TheUser
                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                            by TheUser
                            Hello to everyone ,
                            This is my first post here, and i would like to share with you a small story in case you can help me.
                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                            02-10-2024, 02:07 PM
                          • gurj1979
                            Ubiquiti firmware help. US-8-150W POE
                            by gurj1979
                            Hi guys.
                            I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                            Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                            So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                            Got New chip and writes good.
                            THE PROBLEM...
                            It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                            Does anyone have a Good Firmware I can have?...
                            07-22-2024, 05:13 PM
                          • Slapito
                            Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                            by Slapito
                            I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                            Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                            I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                            I already downloaded the BIOS update file from msi official...
                            10-09-2025, 02:00 AM
                          • wattage
                            AOC AG493UCX 49-inch monitor - Firmware request
                            by wattage
                            Hello Badcaps Community,
                            The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                            07-13-2025, 04:41 PM
