i-joy firmware iled32shhpb01
  • spantor
    • Jan 2020
    • 46
    • spain
    Hello.
    It stays in the logo when I teach and then in black, no gun button and the command do not respond. I find out that it is firmware.
    Any charitable soul that can pass me firmware for spi flash of this iled32shhpb01 with cv309h-x board and hv320wx2-201 panel?
    Thanks in advance
  • spantor
    • Jan 2020
    • 46
    • spain
    Re: i-joy firmware iled32shhpb01
    Somebody could help me ? After a long time I still have not found this firmware
    • lotas
      • Jan 2016
      • 4482
      • Russia
      Post your non-working firmware here, I'll try to fix it.
      • spantor
        • Jan 2020
        • 46
        • spain
        Will be great.
        • lotas
          • Jan 2016
          • 4482
          • Russia
          Will be great.
          Try
          • spantor
            • Jan 2020
            • 46
            • spain
            Try
            Thank you very much for the file. Initially it works, the tv turns on. But some buttons on the remote control do not work, volume, channel change, menu etc. I really don't know if it's a remote control problem or it could be due to the file.
            What do you think ?
            • lotas
              • Jan 2016
              • 4482
              • Russia
              The remote control can be checked through the smartphone camera
              • spantor
                • Jan 2020
                • 46
                • spain
                In what way?
                • spantor
                  • Jan 2020
                  • 46
                  • spain
                  okay. I already found out the way. Actually the buttons do not emit a signal. You have done a great job with the file. I will try to repair the remote control
                  • lotas
                    • Jan 2016
                    • 4482
                    • Russia
                    Turn on the smartphone camera and point the remote at the rear camera and press the remote buttons and you will see the LED flashes on the screen, so you can check all the buttons.
                    • spantor
                      • Jan 2020
                      • 46
                      • spain
                      The command cannot be fixed. I'll order one or I'll put a universal remote. Thanks again for everything . Your help has helped me a lot
                      • lotas
                        • Jan 2016
                        • 4482
                        • Russia
                        Please, was glad to help.
                        • spantor
                          • Jan 2020
                          • 46
                          • spain
                          great man
                          • TheUser
                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                            by TheUser
                            Hello to everyone ,
                            This is my first post here, and i would like to share with you a small story in case you can help me.
                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                            02-10-2024, 02:07 PM
                          • gurj1979
                            Ubiquiti firmware help. US-8-150W POE
                            by gurj1979
                            Hi guys.
                            I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                            Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                            So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                            Got New chip and writes good.
                            THE PROBLEM...
                            It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                            Does anyone have a Good Firmware I can have?...
                            07-22-2024, 05:13 PM
                          • sikocan
                            NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                            by sikocan
                            I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                            However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                            01-11-2024, 01:47 AM
                          • skynetto
                            MSI Z590 MS-7D07 rev 2.1 EC Firmware
                            by skynetto
                            Hello there.
                            I have this mainboard (MSI Z590 Gaming edge - MS-7D07 rev 2.1) with these symptoms.
                            1. SIO_3VA ON
                            2. ATX_5VSB ON
                            3. 3VDSW ON
                            4. Mainboard stucked in Deep_S5 state
                            Problem:
                            RSMRST Incative. (Obviosly everything dead)
                            Tried just for fun to update the BIOS with its Bios flashback function (Push button and USB stick with bios in it).
                            Main Bios restored succesfully.
                            When updating Bios all the voltages comes on except PCH which is not needed.
                            EC Controller: NCT6687D-M
                            External SIO Firmware...
                            03-17-2023, 10:30 AM
                            ME Firmware Cleaning Guide
                            by SMDFlea
                            Here`s a quick ME Firmware cleaning guide.
                            The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
                            (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
                            A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
                            1. Open the...
                            09-09-2020, 09:10 AM
