Sony Bravia KDL-65W850C red tinge and double image
  • bubbajoey
    • Dec 2016
    • 9
    Long time lurker first time post.
    I was recently gifted a KDL-65W850C that had a faulty backlight LED, replaced the strip and it now has a functioning backlight.
    The issues now are that skin tones are red and also I'm getting double images
    and "ghosting"? on right hand side. I have attached pics.
    Also the "tab" on top right of panel is hot to the touch, when I do touch it does affect the picture slightly. The other tabs are cool to the touch. Pic also attached...finger in (pic because camera wouldn't focus)
    Video of image being affected by touching the tab at https://youtu.be/X9Piq9lbjAE
    Appreciate any guidance in sorting this out, promised the wife we'd have a new TV...don't want to let her down :-)
    Let me know if I need to provide more info.
    Cheers
    • 12128
    • U.S.
    Re: Sony Bravia KDL-65W850C red tinge and double image
    Take a card or such and get slight even pressure on that tab you are testing, if it's hot and or black it's probably bad, there's the cof bypass but it's not simple. You may have luck with the "tape cut-off" method, not sure about that one tho.
      • 12128
      • U.S.
      Example of cof bypass there, might need to find one that gives a better step by step process but there's a lot of such videos on youtube: https://www.youtube.com/watch?v=YacI7hWWKJw
      • bubbajoey
        • Dec 2016
        • 9
        Hey thanks for your reply nomoresonys I'll do some research on those two possible fixes.
        But I think I have found the issue and not sure this is repairable.
        The COF looks like its popped see pic.
        Whats the chance of this panel being salvageable?
        Cheers
        • PopsCaps
          Sony Bravia KDL-40V2500 that will not power on
          by PopsCaps
          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
          I do not hear any sound and I cannot see any backlight.
          I have tried disconnecting every cable on each board one at a time to see if anything changes.
          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
          03-25-2025, 11:23 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
          Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
          10-16-2024, 05:15 AM
        • Spc.
          Sony Bravia KD43XF7596BAEP - Android no picture
          by Spc.
          Greetings everyone.
          I also have Sony Bravia, model:
          Sony Bravia KD43XF7596BAEP - Android.
          What happend is that image dissapeared while we were watching tv.
          Diagnostics:
          1. TV turns on, no errors
          2. Backlight turs on, no errors
          3. Power indicator turns on, white color, no errors
          4. Menu works on android, you can hear sound while switching channels
          5. Volume up and down works via TV remote and via buttons
          6. Tunner works, HEVC / MPEG-4 decoder works
          7. I get audio from channels
          8. No picture is present,...
          05-19-2022, 04:28 AM
        • beetle1303
          Sony KD-65X7000E - Screen double images for first few minutes then back to normal
          by beetle1303
          I have gotten this Sony KD-65X7000E TV completely dead. According to owner TV was working fine and suddenly blackout and not able to power on again.
          Checked and found D751 rectifying diode shorted, replaced and now power up and working almost normally:
          1) On power up - display double images, and flicker once every few seconds.
          2) After 3-4 minutes at this state - display suddenly back to perfectly normal (although there are few horizontal lines at the bottom of screen).
          3) Leaving on for few minutes, power off and on again will repeat the same...
          03-11-2023, 02:07 AM
