Sony Bravia KDL-65W850C red tinge and double image
  • bubbajoey
    • Dec 2016
    • 9
    Long time lurker first time post.
    I was recently gifted a KDL-65W850C that had a faulty backlight LED, replaced the strip and it now has a functioning backlight.
    The issues now are that skin tones are red and also I'm getting double images
    and "ghosting"? on right hand side. I have attached pics.
    Also the "tab" on top right of panel is hot to the touch, when I do touch it does affect the picture slightly. The other tabs are cool to the touch. Pic also attached...finger in (pic because camera wouldn't focus)
    Video of image being affected by touching the tab at https://youtu.be/X9Piq9lbjAE
    Appreciate any guidance in sorting this out, promised the wife we'd have a new TV...don't want to let her down :-)
    Let me know if I need to provide more info.
    Cheers
    • 12330
    • U.S.
    Re: Sony Bravia KDL-65W850C red tinge and double image
    Take a card or such and get slight even pressure on that tab you are testing, if it's hot and or black it's probably bad, there's the cof bypass but it's not simple. You may have luck with the "tape cut-off" method, not sure about that one tho.
      • 12330
      • U.S.
      Example of cof bypass there, might need to find one that gives a better step by step process but there's a lot of such videos on youtube: https://www.youtube.com/watch?v=YacI7hWWKJw
      • bubbajoey
        • Dec 2016
        • 9
        Hey thanks for your reply nomoresonys I'll do some research on those two possible fixes.
        But I think I have found the issue and not sure this is repairable.
        The COF looks like its popped see pic.
        Whats the chance of this panel being salvageable?
        Cheers
        • JUCaESAl
          Sony bravia KD-65AF9
          by JUCaESAl
          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
          10-20-2025, 04:03 AM
        • PopsCaps
          Sony Bravia KDL-40V2500 that will not power on
          by PopsCaps
          I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
          I do not hear any sound and I cannot see any backlight.
          I have tried disconnecting every cable on each board one at a time to see if anything changes.
          The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
          My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
          03-25-2025, 11:23 AM
        • alegatorul
          sony bravia kdl-43w756c, no power, no sound
          by alegatorul
          the charger brick has 19,2-19,3 vcc
          changed the inverter board same result.
          where should i start?
          cheers
          11-15-2025, 10:00 AM
        • rimwall
          Sony KD-65x7500D - double image - Tcon or Panel?
          by rimwall
          This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
          I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
          Yesterday, 02:09 AM
        • justin35
          Sony bravia kdl-43w755c - boot loop
          by justin35
          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
          from what i read online it looks to be an emmc issue…
          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
          i took out the board and say an samsung 16gb emmc
          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
          i could try to put one instead of the 16gb one, but will it work?
          where do i get the software from?
          any help will be much appreciated!...
          03-06-2024, 12:26 PM
