Panasonic tx-l47dt65b shutting off
  • Rigger
    • Mar 2021
    • 5
    • Ireland
    Hi Lads, I have a problem with my panasonic tx-l47dt65b tv.
    The tv will power up and work as normal for maybe an hour or two then power off and show a red blinking led continuously.
    If I turn it back on the tv will work again but for a shorter period, like a a half hour and get shorter each time it powers off. Leaving it unplugged overnight will make it run for a couple hours again but same probelm persists. Does it sound like a power board issue?
    Also when it does shut down it cant be turned back on with the remote, only by holding down the power button on the side of the tv for a few seconds.
    Thanks for any help, would love to get this back working.
    • 12276
    • U.S.
    Re: Panasonic tx-l47dt65b shutting off
    Try a factory reset.
      • 12276
      • U.S.
      Probably look in setup and look for shipping condition, will have to set everything back up but might fix the problem, could also try a firmware update.
      • Rigger
        • Mar 2021
        • 5
        • Ireland
        Ok I will try that and see how it goes, firmware is latest version thank you.
        • Rigger
          • Mar 2021
          • 5
          • Ireland
          Well I tried the shipping condition reset and no change still powering off after a half hour or so. Any other suggestions?
            • 12276
            • U.S.
            A guess would be maybe one or more bad capacitors on the powerboard.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              If you could post some photos of your circuit boards, well lit and focused may help.
              If it looks like a heating up fault you could try some freezer spray or a can of Air Duster spray (used to clean keyboards) which if turned upside down does work as a coolant.
              Maybe you can identify the components which when cool allows the set to run again.
              • Rigger
                • Mar 2021
                • 5
                • Ireland
                Hi Dick,
                I've taken some pictures, I hope they are good enough quality.
                When I opened up the back there was quite a bit of dust on the powerboard I got excited as I thought that might be causing an overheat issue, but after blowing it off its still the same.
                Also found the manual and the continuous blink is BL_SOS. Also from what I can see there are no bulging capicitors.
                Thanks for any help
                  When the TV is working, try setting the Backlights level (Not Brightness) in the OSD user menu to as low as possible and see if the TV will stay on longer.
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    by sam_sam_sam
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    HP ProBook 450 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 450 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + APC Back-UPS 700VA boardview and 450 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                    09-06-2024, 08:10 PM
                    HP ProBook 430 G7 + APC Back-UPS 700VA Notebook 400 Specification for Upgrade or Repair
                    This specification for the HP ProBook 430 G7 + APC Back-UPS 700VA Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + APC Back-UPS 700VA boardview and 430 G7 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
