Anyone having issues with the edgelit where it burns on one side? I replaced both left and right side with brand new edgelit and the same left side burned out again. It only lasted one day. I don't want to replace it again with a chance of it burning.
					Un43nu7100
 Re: Un43nu7100
 Yes, we are refusing to do any edge lit back light repairs on Samsung Tv's due to premature failure and what we find when we get in there. The clear diffuser many times get's melted because they are sitting right on top of the led's which will leave light leak where it's melted. Or they can get so hot it can crack the diffuser and you will see the crack behind the panel. If you own a edge lit Samsung make sure it's not set on Dynamic in picture settings and bring the backlights down to 50% or lower. These Tv's were designed to fail and I wouldn't bother spending any money putting in a new set of bar's. This is why they are going to a new backlighting design. Samsung you suck.
			by howardc64Problem
 This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
			by howardc64- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
			by StephenRight SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.05-29-2025, 10:35 AM
			by ravi_1617Hello to all ,
 I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
 Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
 on external VGA port image is perfect /normal , Attached image...
			by GjacksonHi all,
 I have a SMEG cooktop with a EGO 72.08041.002 power board. The two left hand side cooktops started to slowly fail, sometimes stopping with an EA error (Power board failure according to the manual) after a couple minutes boiling some water and eventually they completely failed and now get an EA error on both of them at all times. Visual inspection of the board went over ok, I checked the IGBT's and rectifiers and they seem fine, what should I look at next as this is the first time I'm fixing an induction cooker, I'm suspecting capacitors in this case, Which ones should I look...
- Loading...
