Re: SONY BRAVIA 40WE663 odd problem
maybe a dry joint somewhere, also worth spraying the dc to dc ic with freezer spray to see if voltages stay longer or come back
what are the input voltages measuring like when other voltages are missing
I'm still new to this but you should have 12v and maybe 3.3v on input from MB
Guys what would cause the scaler board voltages to be missing (intermittent) if not the capacitors.Would be the DC-DC IC?
I have been reading alot about this and watching videos but most are in Hindi language and most seem to use jumpers to provide voltage.Leave a comment:
Im sure in the hands of someone experienced this is a very easy fix haha.
Im guessing the fauly lies between the first VIN and the second VIN?Leave a comment:
Ok now the voltages have gone again.
VIN=12V
VCC=3.3V
right after lvds connector.
further up the board: ( I have posted pics to show areas)
VIN=0V
VDD=0V
VCC=1.8V
VONE=0VAttached Filesif you find these attachements useful please consider making a small donation to the site
Guys,
all I can say is I have absolutely no idea what happened just now.
I took voltages and was just about to post them. VONE and VDD WERE MISSING COMPLETELY.
I didnt want to post incorrect info so I went back to double check just as I was about to sit at the pc.
I rechecked VONE and was shocked to see 27.5v suddenly appear.
I looked at the screen and now the set is working.
The only thing I did was to resolder that inductor.
What could it have been.???Leave a comment:
Measure on the test points. The tiny gold circles.Leave a comment:
OK GUYS THNX,,
have been out all day but have watching all the videos I can..I understand a bit more now.
One thing I have to ask is pinpointing the various points relevant to the V labels.
Is there a general rule.
In the photo with the VONE LABEL do I test the small capacitor ? Or is it anywhere on that large track the label sits on.?Attached Filesif you find these attachements useful please consider making a small donation to the site
I'm still learning, but I was going to say check vone and voffe voltages should be around 30v and -8v and make sure they are stableLast edited by Questcom; 03-21-2021, 07:38 PM.Leave a comment:
Ok, here's what to look for testing the driver board, a video explains it a lot easier than words can: https://www.youtube.com/watch?v=Nh1ZjtI7KK8Leave a comment:
well that cap turned out to be an inductor which has been replaced as it wasnt actually a faulty part.Leave a comment:
Well if none of the other caps on the driver board are reading bad, replace the bad one, it may be the only problem or did you already replace it?Leave a comment:
Makes sense.Good thing I kept the part as I will now resolder to the board.
Any other ideas as to what would give me image for secs then amps dropping then image goes away.?
Im not sure what to check now.Leave a comment:
tested out of circuit
good state: inductor should be short and capacitor should be open
bad state: inductor would be open and capacitor short (maybe discoloured due to heat)Leave a comment:
Ok just tested again the 3 on the mainboard and they do all test as short so Im guessing they must be inductors.Leave a comment:
Right, make sure it is a cap, you should see a C somewhere beside the cap, L for inductor. Ok, I see now that they are not marked at all.Last edited by nomoresonys; 03-21-2021, 01:55 PM.Leave a comment:
Aah interesting. Can anyone else confirm this part is NOT a capacitor.?
How would one tell the difference.Google images confirm they do look very similar.Last edited by vikivng; 03-21-2021, 01:53 PM.Leave a comment:
If those caps on the mainboard are testing short with NO other boards hooked up to it, remove one and test it and also test the other one while still on the board, you need to track down this short.Leave a comment:
looks more like a inductor to me and not a capacitorLeave a comment:
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by alegatorulsony bravia kdl-43w756c, no power, no sound
the charger brick has 19,2-19,3 vcc
changed the inverter board same result.
where should i start?
cheers -
by crackedprintI have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
I have tried a Cold Reset as per the service manual.
I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
I have looked all the way through the service manual and tried many online...-
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM - Loading...
