SONY BRAVIA 40WE663 odd problem
  • vikivng
    • Feb 2019
    • 228
    Hi guys,
    has anyone seen this problem before.?
    Sony 40 inch tv turns on ,shows logo and normal picture for approx 10 secs then the image disintegrates into grey screen.
    No input from remote.
    This model has no TCON board.
    Any ideas o this one pls.?
    thnx
  • vikivng
    • Feb 2019
    • 228
    Re: SONY BRAVIA 40WE663 odd problem
    hi anyone there.?
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      The Tcon is probably part of the panel strip.
      Can you post photo's.
      It doesn't sound too good. Check the state of where the panel ribbons join the panel and see if there has been any liquid spill in those area also how hot do the COF tabs become.
      • vikivng
        • Feb 2019
        • 228
        Thanks.
        I will post a couple photos.
        When I connect via power supply I get a drop in amps exactly when the image goes, from 1.98 amps to 1.84 amps.
        Could this a capacitor.?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          What volt/amps is your power supply?.
          A web search says
          "Original Sony KDL-40WE663 KDL40WE663 UK Adapter Charger 19.5V 4.36A"
          so I would expect the current drawn to be a lot higher than you have given.
          • vikivng
            • Feb 2019
            • 228
            A web search says so I would expect the current drawn to be a lot higher than you have given.
            Hi I have a 30v 10a supply.
            This issue also presented itself with the original power supply.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Are you saying you have a variable dc power supply set to 19V and the current drawn is as given above?
              When it's showing a normal image for approx 10 seconds as you say, what is the current drawn by the supply?
              • vikivng
                • Feb 2019
                • 228
                Hi ,
                sorry been out all day and have not had too much time to check any further.
                When I power on with power supply set at 19v. The tv boots up drawing incremental amps until its peak draw at 1.98. It stays there for however long (random at this point) the image shows normally. Then , the instant the image disintegrates, the draw goes down the 1.84 amps.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Thanks for the feedback.
                  Can you post good sharp pictures of you lcd panel board.
                  I wonder if one of the capacitors on it is failing. Seems to becoming a common problem.
                  • vikivng
                    • Feb 2019
                    • 228
                    Close up inspection capacitors look new.
                    Obviously there would be no short to ground here as the tv would turn on at all ?
                    What am I checking for.?
                    I will try to get good photos today
                      • 12332
                      • U.S.
                      Can't tell just by looking, here's one example, he's using diode mode in this one, can also check for very low ohms: https://www.youtube.com/watch?v=jLd6QO7Z7m4
                      • vikivng
                        • Feb 2019
                        • 228
                        Here are some pics of the board.
                        There is 12v on the output of the connector and at certain points on the board.
                        At the testing points going to the COF tabs I am getting .400v on one side and .300v on thw other.
                        #Is there meant to be 12v going to the tabs at all.?
                        There is also 1.8v at a couple of the caps going to the tabs.
                        can someone help me understand where the 12v needs to end.?
                          • 12332
                          • U.S.
                          Mr Barton said he wondered if maybe a cap is failing, I posted a video of testing them, tv isn't on our bench, we can't do it for you.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            With the power to the set switched off check across the smd capacitors to see if any of them measure short circuit.
                            • vikivng
                              • Feb 2019
                              • 228
                              Thnx for replying.
                              this cap is testing short. I am assuming this should not be showing as such.?
                              Could this be the issue.?
                              Also getting 00v at both legs of that cap when power is on.
                              Looks like the culprit.?
                              • vikivng
                                • Feb 2019
                                • 228
                                Yes I agree.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  It may not be the capacitor but something connected to it. The only way to be sure it's not the capacitor is to unsolder it and check again.
                                  • vikivng
                                    • Feb 2019
                                    • 228
                                    Great ..The cap has been removed and the short is gone..
                                    Next question before I test. Is this an integral component.?
                                    If so,,do i match by physical size.? Can I test without it ?
                                    thnx guys.
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      It looks like part of the step-down voltage system so would be needed. I don't think the set would work correctly with it missing.
                                      Is there any other capacitor that looks identical in shape and size on the board you could compare it to in order to get an idea of its capacitor value.
                                      • vikivng
                                        • Feb 2019
                                        • 228
                                        It seems this was the only capacitor of this size on the board.
                                        Is it a matter of testing other caps to see if it works since I have no reference point?
                                        • JUCaESAl
                                          Sony bravia KD-65AF9
                                          by JUCaESAl
                                          Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                          Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                          10-20-2025, 04:03 AM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • alegatorul
                                          sony bravia kdl-43w756c, no power, no sound
                                          by alegatorul
                                          the charger brick has 19,2-19,3 vcc
                                          changed the inverter board same result.
                                          where should i start?
                                          cheers
                                          11-15-2025, 10:00 AM
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • justin35
                                          Sony bravia kdl-43w755c - boot loop
                                          by justin35
                                          i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                                          from what i read online it looks to be an emmc issue…
                                          i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                                          i took out the board and say an samsung 16gb emmc
                                          i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                                          i could try to put one instead of the 16gb one, but will it work?
                                          where do i get the software from?
                                          any help will be much appreciated!...
                                          03-06-2024, 12:26 PM
