LG 50LA6970-ue tv picture keeps coming on and off yet audio is fine
  • akobtan
    • Mar 2021
    I have a 50LA6970-ue lg tv. With any kind of input (antenna, hdmi, etc..) the audio works fine, but the image keeps turning on then going black then coming back on then going black, etc.. This cycle of image coming and going keeps happening as long as the tv is on. I checked removed the backcover and checked the backlights while the tv is on, and nothing happens to them even though the problem is still there on screen. I measured the 3.5, 12, and 24 voltages from the power board and they all seemed fine. I tried changing the tcon board with a new one, but the problem is still happening.
    I am a newbie DIYer, but in my humble opinion I suspect the problem is very different from normal panel issue symptoms I see online, and I have a feeling there is something else at work here that could be more easily fixed. From what I read, panel issues are not worth fixing due to cost and unavailability of gear for a DIYer.
    I can create a video of the problem if that helps. I would appreciate your guidance on this issue.
  • nomoresonys
    • 12323
    • U.S.
    Re: LG 50LA6970-ue tv picture keeps coming on and off yet audio is fine
    Test the voltages at the connector on the powerboard with EVERYTHING hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts.
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • mecha1166
      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
      by mecha1166
      KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
      11-25-2024, 05:22 PM
    • CapLeaker
      Dell ATX PSU won’t start, but forcing it works fine?
      by CapLeaker
      Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
      Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
      10-28-2024, 06:59 PM
    • Rauni
      Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
      by Rauni
      Hello, this is my first post on this forum, and my first attempted to repair a TV.
      My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
      Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
      Read also that we should test what happens if we...
      10-01-2023, 12:06 AM
