ANOTHER Vizio M65-C1 No picture Issue
  • sbrahaum
    • Feb 2021
    What happened:
    I was watching YoutubeTV on a ROKU streaming device when the screen froze with all sorts of garbled colors, shapes, half legible words, etc. The audio was still streaming. I grabbed the TV remote and turned the TV off. Waited a minute or so and powered back on, no picture. I am not sure about sound as I couldn't navigate anything.
    What I've done:
    Performed the flashlight test. I don't see anything.
    Measured voltages on the power supply:
    CN9101 -__________OFF____ON
    PIN 1 - +5V/+3.5V__5.1V____5.2
    PIN 3 - +12V -______19V____19.2
    PIN 5 - +12V -______19V____19.3
    PIN 7 - +12V_A _____19V____19.2
    PIN 9 - GND -________0V_____0
    PIN 11 - GND ________0V_____0
    PIN 13 - 3D _________0V_____0
    PIN 15 - ON/OFF _____0V_____0.08
    CN9102 -
    PIN 2 - +5V/+3.5V -___5.1V__5.2
    PIN 4 - +12V - _______19V___19.0
    PIN 6 - +12V - _______19V___19.0
    PIN 8 - +12V_A -______19V___19.0
    PIN 10 - GND -________0V____0
    PIN 12 - GND - ________0V____0
    PIN 14 - PS_ON -_______0V___3.5
    PIN 16 - DIM -_________0V____3.3
    CN9201 -
    PIN 1 - ON/OFF - ______0V____0.0
    PIN 3 - 3D ___________0V____0
    PIN 5 - GND __________0V____0
    PIN 7 - GND __________0V____0
    PIN 9 - GND -_________0V____0
    PIN 11 - +24V - _______0V____24.0
    PIN 13 - +24V - _______0V____24.0
    CN9203
    PIN 2 - DIM - _________0V____3.3
    PIN 4 - +12V - ________19V __19.1
    PIN 6 - GND - _________0V____0
    PIN 8 - GND - _________0V____0
    PIN 10 - +24V -________0V____24.0
    PIN 12 - +24V -________0V____24.0
    PIN 14 - +24V - ________0V____24.0
    Also, nothing on the main board side of the ON/OFF. Am I right that the signal for this come from the main board?
    From reading posts here (thank you!) I think I know that PIN 15 is the BL ON signal from the main board. Obviously, 0.08 doesn't cut it. So...I found one on eBay and thought it was the obvious solution. Just got it today and it reads the same as above.
    My question is: Can anything else be causing this or did I get suckered on eBay? I don't have a problem returning the board but don't want to waste the sellers time and money unless I'm confident I'm in the right.
    Thank you!
  • neilc6
    • Nov 2015
    • 1550
    Re: ANOTHER Vizio M65-C1 No picture Issue
    Your replacement board is bad as well. ON/OFF comes directly from the processor.
    One good thing about buying boards from ebay is the money back guarantee.
    https://www.badcaps.net/forum/showthread.php?t=76708
    • sbrahaum
      • Feb 2021
      OK, that is what I thought. Thank you for the help and confirmation!
      • neilc6
        • Nov 2015
        • 1550
        I purchased a guaranteed working and tested board with the same failure previously. If sellers takes returns, then easy for an unscrupulous buyer to return a bad board and it gets resold.
        • sbrahaum
          • Feb 2021
          The seller insisted he tested it personally and asked for pics of my board to confirm I bought the right one. I also sent him pictures of the voltage in standby and powered up. He refunded me immediately.
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • CyberPhoenix
            Issue with picture quality of Sony bravia TV
            by CyberPhoenix
            Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
            01-22-2024, 02:08 AM
          • gavric
            Vizio M70-C3 Half picture is bad, main board on its last leg?
            by gavric
            Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
            When tv powers on vizio V logo shows nice on whole screen. picture 1
            When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
            When i start youtube picture shows on left side fine, right is all scrambled. pic 2
            When i click video to start playing picture goes black(like when you change...
            09-02-2021, 08:55 PM
          • EazyBone
            Vizio P759-G1, Tcon issue?
            by EazyBone
            Got this TV free. Guy said it tries to turn on and doesn't. I haven't seen this specific issue before but shown in video. Any way to test the screen to rule it out on these Vizio? Or anyone seen this issue before?
            Any help appreciated
            https://youtu.be/tPeV2Q7TXIQ?feature=shared
            03-22-2024, 03:25 PM
          • csmith
            Vizio D50u-D1 Powers up no picture
            by csmith
            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
            issue. Set will power up with remote but not power off....
            07-11-2025, 11:52 AM
