JVC LT-40N530AA boot loop
  • zump
    • Feb 2021
    • australia
    Elec Engineer here trying a hand at TV Repair! I got this unit, TV turns on and JVC logo appears. However, the standby front LED flashes green and red for a few seconds, then turns off and the process repeats.
    From research, I have found this is due to corrupted firmware in the EEPROM (or is it SPI flash?)
    Does anyone have the firmware for this device? Or any possible solutions?
    Model: JVC LT-40N530AA
    Main board: TP.SIS231.P83
  • arizanotlari
    • Nov 2014
    • 158
    • Turkiye
    Re: JVC LT-40N530AA boot loop
    try this : https://yadi.sk/d/HidEqxMgyAvUXQ
    https://www.badcaps.net
    • zump
      • Feb 2021
      • australia
      Tried this but now the logo is gone and just get a blank screen.
      Any other ones out there?
      • NolesFan
        Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
        by NolesFan
        Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
        10-24-2024, 06:36 PM
      • Takeatry
        Yet another Samsung QLED Boot Loop
        by Takeatry
        Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
        10-04-2024, 02:57 PM
      • blaster_
        Samsung UE49MU6105K - boot loop, horizontal lines
        by blaster_
        Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
        Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
        06-22-2022, 05:19 PM
      • torchzack
        Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
        by torchzack
        Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
        I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
        Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
        08-28-2023, 07:42 AM
      • Daniel Larsson
        Firmware file for LG SK10Y Soundbar stuck in Please wait loop needed
        by Daniel Larsson
        My LG Soundbar, SK10Y, has somehow ended up in an endless "PLEASE WAIT" loop and I am now starting to suspect that the firmware is causing this, and I can't manage to connect via the app to push a new firmware in as it never really starts.
        I can trick it to start via HDMI ARC and it actually starts up, flashes OPTICAL and then goes to ARC where the sound (including sub) is perfect, but the white led indicator keeps blinking and after 20 seconds it says "GOOD BYE" and shuts down.
        During these seconds the function button is not working...
        08-13-2025, 10:29 AM
