LG 43LJ594V-ZA, turned off.
  • amennone
    • Feb 2015
    • 63
    • italy
    Power: LGP43DJ-17F1
    Fault: No power on the secondary.
    I have checked diodes and transistors and they are ok. Resistors are o.k.
    Replaced IC101 = SSC3S927, IC601 = SSC2016, still no secondary side voltage
    I need the schematic and some repair tips.
    Thanks and good job .
  • KYBOSH
    Tektronix 422 with No Power
    by KYBOSH
    Picked up a Tektronix type 422 oscilloscope locally for a few bucks last year.
    It wouldnt power on at all so I stowed it away under my bench for later testing.
    Today I remembered it was down there and pulled it out to see what was what.
    I checked for continuity and everything checked out.
    There was a burned smell and a resistor was replaced with a temporary replacement (see yellow box in picture).
    The burned smell is very pungent/acidic and I am not familiar with these vintage electronics to know whether I am smelling the remains of the replaced resistor or...
    02-03-2024, 07:56 PM
  • estabilito
    Tips geting oxidized when using wick
    by estabilito
    Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
    i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
    Temperature: 350-365celsius
    station: jbc cd-2bqe
    Wick: edsyn
    flux: warton hf rework jelly
    Do you have any tips?...
    04-12-2025, 11:55 AM
  • peter99
    HP 245 laptop not charging when turned on
    by peter99
    helo everry body!!!
    My laptop HP 245 AMD 14-FP5-6L -GDDR5X2 has a battery charging circuit error:
    - If not power on, battery charge ok.
    - if i turn on the power, not charging the battery ( the battery charging indicator light, from yellow to white)
    The laptop only charges when not turned on. I have changed the battery and charger, but the situation remains unchanged.
    I replaced the BQ 25A charging IC but the device only charges when not turned on.
    everyone please help me with solution, what should i do ?
    thanks a lot !!!!!...
    04-04-2025, 07:35 AM
  • bykanovm
    Thinkpad W541 Works from the mains and charges the battery only when it is turned off
    by bykanovm
    Lenovo Thinkpad W541 Wistron LKM-1 WS MB 12291-2 Works from the network and charges the battery only when it is turned off.
    If you press the power button, the laptop turns on and works from the battery, but does not take power from the power supply.
    If you boot into Windows and close the lid while working, thereby putting the laptop into sleep mode, the laptop begins to charge the battery.
    even checked it this way: I bring a neodymium magnet to the Hall sensor during operation - the screen goes out and the battery starts charging.
    Also, the laptop does not turn on without...
    04-02-2025, 02:45 AM
  • corrize
    Quality solder iron tips and Kapton ?
    by corrize
    Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
    I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
    Do you have brand of qually tips pls ?
    Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
    05-24-2021, 11:35 PM
