Apex CRT TV - Blue Screen
  • mu2
    • Oct 2009
    • 217
    Got a call from a friend that is having problems with an Apex A72704S (Chassis CH-10C).
    Worked great one night - next day it's only showing a blue screen on the cable input. I searched the web for common problems and if the parental lock is turned on you will see a blue screen with a red key. They do not have the red key and the lock is not turned on. External video and audio inputs work ok and other tv's will work on this cable connection.
    Is this a common problem on this model / brand tv?
    Thanks for your help.
    Mike
  • hardwareguy
    • Jun 2006
    • 405
    Re: Apex CRT TV - Blue Screen
    It appears that the tuner module has failed.
    I'm not in the TV business full time so I'm unsure how common it is. In general, tuner failure is rare.
    • tmwalsh
      • Jan 2009
      • 119
      Just for practice, I would inspect the solder connections on the tuner. If the voltage supplied/applied is marked, I would test that it is correct.
      Good luck in getting any tech info on this product line. I have yet to see an Apex schematic or any other service information.
      tom
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • ulthi
        Samsung QE50Q60TAU - Flashes black/blue screen
        by ulthi
        My tv is not able to turn on. I flashes between black and vague blue screen (see video)
        I have tried different resets and have also replaced the main board - but nothin has changed.
        Any suggestions?
        https://youtu.be/acYQ-ImmhWA
        10-14-2025, 01:48 PM
      • gbbradshaw
        Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
        by gbbradshaw
        Hi.
        I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
        02-22-2023, 01:31 AM
      • siuras676
        Dell XPS Plus 9320 blue screen and rebooting
        by siuras676
        I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
        First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
        However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
        Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
        04-07-2025, 12:10 PM
      • Abdulrhman Alabsi
        Dell precision 7530 blue screen
        by Abdulrhman Alabsi
        I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
        02-09-2025, 10:39 AM
