Logik L40DIGB20 inverter SSI 400 14A0
  • Dreadnought
    • Feb 2021
    • 10
    • England
    Hi. Sorry if I have posted this twice, the first thread showed an envelope with a return arrow, leading me to think I'd tried to post too soon after my introductory post. Secondly I apologise if I break any forum rules/manners, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
    Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine, and the inverter board is getting its 24v. From previous threads on the inverter board (SSI_400_14A0), I've heard that these boards have issues with the AO4614 mosfets failing. On the underside of the board, there is an obvious hotspot under one of the fets, however none test as shorted. The SMD fuses show continuity, the transformers all show the same Ohm reading and do not test open circuit. The Ccfl bulbs seem to light with some only glowing half way along, before turning off...as if they're not getting enough power. The electrolytic caps are all fine, not shorted and voltages seem good on test. I've heard on here that the soldering on the '000' jumpers sometimes need touching up, so I've done all of them again, adding extra solder. The main chip SEM2107 is receiving power to VCC pin. I've tried swapping bulbs around to see if it was a bad bulb, as one bulb glowed a red colour...but in the new location, it lit up half way.
    If anyone could help me out, I'd really appreciate it. I'd buy a new inverter board, but without being sure that's the true issue, the cost of repair would begin to outweigh the Tv's value.
    Many thanks in advance.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Logik L40DIGB20 inverter SSI 400 14A0
    It sounds from what you have written that you have a failed CCFL tube.
    • Dreadnought
      • Feb 2021
      • 10
      • England
      Any advice I get, I'm very grateful for, so thank you. I was beginning to think it might be a tube...so I got another 40" tv that has a Samsung screen/backlight assembly/ccfl backlight...but typical of my luck, the ccfl tubes are slightly thinner!!! Do you think I'd end up blowing them if I replaced them all of the ones I'm posting about with these thinner diameter ones?
      Thanks once again.
        • 12079
        • U.S.
        Good question, what's the full model number of both tvs?
        • Dreadnought
          • Feb 2021
          • 10
          • England
          TV with bad inverter or ccfl tube is a 40" logik L40DIGB20. It has a Samsung LTA400HA07 screen assembly with 14 ccfl tubes inside.
          The donor TV is a Samsung Le40m87bdx/cry. It has a Samsung LTA400HT-L06 screen assembly which has 20 ccfl tubes inside, but these are slightly thinner, but same length of course.
          After trying everything with the L40DIGB20 inverter board, (as per original post) I had the idea of trying to replace all of the ccfl tubes just on a whim, as I had the Samsung Le40m87bdx as parts, so didn't spend anything.
          The inverter boards on both TVs are very different though, leading me to be a bit dubious about trying the tubes. The L40DIGB20 supplies 24V from its power supply, to 4 high voltage transformers on the SSi 400 14a0 inverter board. The Le40m87bdx power board had a high voltage transformer built in to its power supply, with 2 high voltage leads (too high for my equipment to test) which go to its inverter board and 20 very small transformers. 2 very different arrangements leading me to think the tubes are going to be very different watts. Hence why I love forums like this, because where all this is concerned, I'm open to any advice no matter how small.
          Thank you.
          • dick_barton
            • Aug 2015
            • 6642
            • Wales
            I have used a CCFL tube from a different set successfully. The first one I tried did not work but a second tube from another set worked well.
            • Dreadnought
              • Feb 2021
              • 10
              • England
              That's reassuring. I'm pretty sure I'm going to try it, because both Tvs were donated to me friends saying "can you use these for something?". I'll let you know what happens! Thanks again mate.
              • Dreadnought
                • Feb 2021
                • 10
                • England
                Hello again mate. Changed 2 tubes. They work. Now all tubes light fully all the way across, but then they all go out again light before. Leading me to think it's def the ssi-400-14a01 inverter panel. Somethings causing the control chip on that inverter board to shut down after starting. Any ideas?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  The position in which the original tube was positioned which was lighting only half way; can you trace it back to the transformer it was connected to and look on the underside of the board to see if it is discoloured.
                  Also have a read through this thread.
                  https://www.badcaps.net/forum/showth...=Ssi_400_14a01
                  • Dreadnought
                    • Feb 2021
                    • 10
                    • England
                    The board below one transformer...maybe the one leading to the tube (I'll check after work) does show slight discolouration, but the worst discolouration (light brown, not burned) is underneath an AO4614 mosfet...which leads to that particular transformer...yet is doesn't test shorted. I must admit, I've only tested the transformer's resistance in circuit to compare it to the other 3 transformers on the inverter board. Kinda quick check to make sure it wasn't OL. It reads the exact same as the other 3, so maybe wrongly assumed it was OK. Thanks again mate for this help.
                    • Dreadnought
                      • Feb 2021
                      • 10
                      • England
                      Just to let you know mate, I checked the inverter board one last time with a fine toothed comb, and found one jumper that I hadn't resoldered. I checked its track for continuity and there was none. I resoldered it and to my absolute shock...and joy of course, it works! All it turned out to be was a tiny smd jumper. Take care mate and thanks again.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        Well done. Glad you got there in the end.
                          • 12079
                          • U.S.
                          So to be clear, it had a bad tube or 2 or just a bad jumper solder joint?
                          • Dreadnought
                            • Feb 2021
                            • 10
                            • England
                            After replacing the 2 tubes alone, it still didn't function properly and stay lit, but once the bad jumper joint was found, all tubes (including the 2 I'd replaced) stayed on. So the first thing I thought was "put the original tubes back in"...but it again didn't work. So I think it was both problems combined. Maybe the bad jumper caused the tubes to fail. All good now though.
                              • 12079
                              • U.S.
                              Thank you.
                              • ttmi100x
                                HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                by ttmi100x
                                Greetings everyone,
                                I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                Upon closer inspection...
                                07-31-2024, 06:36 PM
                              • Dreadnought
                                L40DIGB20 Logik 40" inverter/backlight issue.
                                by Dreadnought
                                Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
                                Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
                                02-08-2021, 12:28 PM
                              • signal.quest
                                Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                                by signal.quest
                                I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                                I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                                09-30-2024, 11:21 PM
                              • x_orange90_x
                                by x_orange90_x
                                01-29-2025, 09:24 PM
                              • Gentian
                                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                by Gentian
                                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                03-06-2023, 07:07 AM
