how to turn down backlight on philips 32pfl5520d
  • jimbofz
    • Apr 2013
    • 539
    hi after most repairs, i turn down backlight ,to acceptable level.
    on this philips using lc7.2e chassis, (ccfls with inverter board)
    cant find in menu how to do it
    ive looked through s manual and no mention of backlight adjustment?
    any ideas please
  • jimbofz
    • Apr 2013
    • 539
    Re: how to turn down backlight on philips 32pfl5520d
    any comment please?
    • R_J
      • 9624
      It's not that critical with ccfl as it is with led's . Adjust the brightness, that might control the ccfl brightness.
      • jimbofz
        • Apr 2013
        • 539
        thanks for taking time to reply ,
        in the past ive had a few tvs with ccfl causing no backlight
        sometimes you can simply link out the one ccfl thats failing
        and get acceptable display just for test purposes .
        so when possible i try to prevent them being driven too hard.
        • ovrax
          Philips 55PUS6804/12 turn on & off (probably backlight issue)
          by ovrax
          First of all, please excuse me as I'm quite new to this field.
          I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
          I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
          The Ambilight works perfectly and stays on.
          No sounds.
          Thanks in advance.
          08-25-2024, 04:33 AM
        • chestercc
          Philips TV Backlight Repair
          by chestercc
          So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
          My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
          The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
          11-18-2022, 01:15 PM
        • ohren
          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
          by ohren
          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
          The setup is basically:
          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
          Transistor is switching the 3.5 V supply on the power board....
          12-05-2024, 11:10 AM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
