how to turn down backlight on philips 32pfl5520d
  • jimbofz
    • Apr 2013
    • 539
    • uk
    hi after most repairs, i turn down backlight ,to acceptable level.
    on this philips using lc7.2e chassis, (ccfls with inverter board)
    cant find in menu how to do it
    ive looked through s manual and no mention of backlight adjustment?
    any ideas please
  • jimbofz
    • Apr 2013
    • 539
    • uk
    Re: how to turn down backlight on philips 32pfl5520d
    any comment please?
    • R_J
      • Jun 2012
      • 9588
      It's not that critical with ccfl as it is with led's . Adjust the brightness, that might control the ccfl brightness.
      • jimbofz
        • Apr 2013
        • 539
        • uk
        thanks for taking time to reply ,
        in the past ive had a few tvs with ccfl causing no backlight
        sometimes you can simply link out the one ccfl thats failing
        and get acceptable display just for test purposes .
        so when possible i try to prevent them being driven too hard.
        • ovrax
          Philips 55PUS6804/12 turn on & off (probably backlight issue)
          by ovrax
          First of all, please excuse me as I'm quite new to this field.
          I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
          I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
          The Ambilight works perfectly and stays on.
          No sounds.
          Thanks in advance.
          08-25-2024, 04:33 AM
        • chestercc
          Philips TV Backlight Repair
          by chestercc
          So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
          My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
          The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
          11-18-2022, 01:15 PM
        • ohren
          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
          by ohren
          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
          The setup is basically:
          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
          Transistor is switching the 3.5 V supply on the power board....
          12-05-2024, 11:10 AM
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • DoOm86
          philips 55pft5500/12 Backlight issue. What am I doing wrong?
          by DoOm86
          TV philips 55'' no backlight (image ok).
          I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
          What am I missing?
          And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
          04-16-2024, 03:47 PM
