What would cause a TV to do this? (Old Sony)
  • CapsDude
    • Jan 2021
    • 50
    So there's an old TV in the living room. The picture starts out fine for a few minutes then does what's in the pic. Sometimes it'll go back to working fine or stays like that until it's turned off. The sound works fine so I just use it for the music channels. Is it connection issue or something inside?
  • R_J
    • 9535
    Re: What would cause a TV to do this? (Old Sony)
    If the fault is intermittent, check the connections on the vertical output ic and in the vertical output section.
    This is a Sharp not a Sony
    How about a model number? and when you take the back off, provide some pictures of the chassis.
    • CapsDude
      • Jan 2021
      • 50
      Haha, and it says Sharp in the pic too. See, what happened was..
      The sticker fell off in the back with the model number and all that but from doing some research it appears to be 25j-s100. I'll take the back off and take the pics tomorrow.
      • R_J
        • 9535
        There is likely a model/chassis sticker inside somewhere. If this is the model (or 25k-s100) the vertical output ic is IC501 mounted to a heatsink near the center of the board
        • N/East Unlocker
          • Jan 2021
          • 3
          If 25j-s100 , resolder ic501 ( TA8403K )( remove old solder / clean / resolder )
          For good measure also replace c508 35v 100uf & c510 35v 1000uf
          B.Rgds
          John
          • CapsDude
            • Jan 2021
            • 50
            Finally got the back off.
            I took it to my room and hooked it up to a different coaxial cable and it seemed to work when I moved the cable to a certain position but the tuner is fine. Dont think its the cable cause it works on the other TV.
              • 12145
              • U.S.
              It's an old crt tv right? if it's not a simple fix, you can grab another, they give them away daily on craigslist, just always make sure the meeting place isn't a dark alley.
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                have you checked recent prices of old crt tv.s and monitors ?
                • R_J
                  • 9535
                  If you want it fixed, do what we suggested and solder the vertical output ic.
                    • 12145
                    • U.S.
                    Here in the U.S. they are FREE in perfect working order, might be a different story in your neck of the woods. I gave all mine away about 10 years ago.
                    • petehall347
                      • Jan 2015
                      • 4426
                      • United Kingdom
                      was like that here .. not even worth repairing back then . but now lots want them for gaming .
                        • 12145
                        • U.S.
                        Not a big gamer but when I do I gotta have at least 720P.
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
                        • dkneyle
                          Sony KDL-46HX850 Can't upgrade/update firmware
                          by dkneyle
                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                          09-25-2024, 10:44 PM
                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-06-2024, 05:27 AM
                        • mecha1166
                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                          by mecha1166
                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                          11-25-2024, 05:22 PM
                        • CapLeaker
                          Dell ATX PSU won’t start, but forcing it works fine?
                          by CapLeaker
                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                          10-28-2024, 06:59 PM
