HiSense 50CU6000 screen goes black after a few seconds
  • MikeRWK
    • Jun 2017
    • 121
    You can turn it on and it will boot up and after a few seconds the screen goes black but the backlight stays on and there's still sound. It will display picture briefly before it goes out.
    Here it is coming on without a video source, there are some lines and tracers.
    https://streamable.com/css91z
    Here it is with a video source, no lines or anything.
    https://streamable.com/y79wte
    I'm also wondering if this transformer should have voltage going through that outer frame part in the picture, this was measured using hot ground.
  • MikeRWK
    • Jun 2017
    • 121
    Re: HiSense 50CU6000 screen goes black after a few seconds
    Just wanted to add vgh starts at 21.9v then drops to 21.5v and then 0.3v when it happens, the 12v pin on tcon reads 11.9v.
    • MikeRWK
      • Jun 2017
      • 121
      I've isolated the problem to the tcon, plugging it back in with the tv on it runs for the same 8-10 seconds then dies.
        • 12331
        • U.S.
        I wouldn't rule out the mainboard as the culprit.
          • 12331
          • U.S.
          Try unplug tv, unhook cable from mainboard to tcon, plug power cord back in, turn tv on, see if you have the red led lit up at the optical audio output on mainboard and if it stays on.
          • MikeRWK
            • Jun 2017
            • 121
            The light comes on then goes out.
            • Diah
              • Feb 2013
              • 6610
              could you show us the whole back of the set boards??
              the easy way to know why it goes black by trace the live log of the main boards via the service jack.
              • MikeRWK
                • Jun 2017
                • 121
                Here's the main board do you need pics of the other boards?
                • Diah
                  • Feb 2013
                  • 6610
                  you have on the main boards between the USB & HDMI 2 audio jack one of them are service jack .. can be used with any TTL serial with pc and terminal to read the log while the set booting as well the issue when it turn the screen off.
                  if you are familiar with terminal and Linux platform i think you know what i am talking on.
                  by the way... what will happen if you feed it with signal and disconnect one ribbon at atime between panel & t-con did the issue remain
                  • MikeRWK
                    • Jun 2017
                    • 121
                    I know what you're talking about but I have no experience with using terminal to do anything like this. What's a good linux distro I can boot from a usb drive to do this?
                    • Diah
                      • Feb 2013
                      • 6610
                      then download this firmware extract and flash it via usb formated fat32 .. press ok or power on the RC while you plug in the tv at wall socket
                      • MikeRWK
                        • Jun 2017
                        • 121
                        With the left tcon cable unplugged (right side of the screen when looking at it) the tv works and doesnt shut off.
                          • 12331
                          • U.S.
                          • Diah
                            • Feb 2013
                            • 6610
                            Man ...i asked you to feed signal.. we want to see when there are signal load on the t-con and panel.... also you need to do same way disconnect the other side
                            • Diah
                              • Feb 2013
                              • 6610
                              LOL..
                              its issue that t-con cant handle 2 channel signal... 99% firmware need to re flash.... and the reset 1% T-con HW fault
                                • 12331
                                • U.S.
                                ^Yep, I posted right before he said he got it to stay on after tcon disconnect.
                                • MikeRWK
                                  • Jun 2017
                                  • 121
                                  Sorry I missed that part. The tv will work with only one cable plugged into the tcon, either side works. There is also a horizontal line on one side that I've taken a pic of, the tv's menu items and stuff have lines coming from them.
                                    • 12331
                                    • U.S.
                                    +1, what is the result?
                                    • Diah
                                      • Feb 2013
                                      • 6610
                                      you need to do exact point after point with out signal.
                                      1- you need screw the t_CON to chassis al least 2 screw 1 at each side
                                      2- disconnect only the ribbon as you did first time ( the left front side should display picture and other side will be white.... so you can see the menu setting when you call it )
                                      3- call the menu setting and go down to audio setting you need to inter service menu 1-9-6-9
                                      under first page there are some things clear chip ... if you are not sure.. upload photo to tell you which need to initial the chip ( hard reset ) the set will go standby... plug it from wall socket and put the ribbon back then plug in and start the set... tell the result
                                      • MikeRWK
                                        • Jun 2017
                                        • 121
                                        I can't see the menu now I'm only getting a quarter of the screen on that side. I didn't notice before I didnt have the tcon screwed down and it lost ground, did I damage something?
                                        • HTR-Informatique
                                          by HTR-Informatique
                                          02-09-2025, 06:51 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • VcemPzd
                                          Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                                          by VcemPzd
                                          Hello everyone !
                                          My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                                          04-28-2025, 10:14 AM
                                        • DaniK
                                          Acer Aspire E5-574-52RH - black screen
                                          by DaniK
                                          I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                          Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                          Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                          Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                          The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                          Symptoms are:
                                          - random black screen after displaying Acer logo...
                                          02-21-2024, 06:27 AM
                                        • EUWest
                                          Hisense H49M3000 PSU buzzing + Black screen after 20min
                                          by EUWest
                                          Hey Folks just got another Hisense with an unusual Problem.
                                          After plugging in its starts buzzing on the cold side. Could not located it 100%, but seems like transformer/capacitor.
                                          TV has 1 horizontal Line, often static. After 10min screen gets flickering and after about 20min screen gets Black while Sound is on. After turning off and on screen appears back for about 5min and then went Black again.
                                          I checked LED Voltage:
                                          While Screen is on about 115v
                                          While Screen is Black also about 115v
                                          LED Connection unplugged also 115v
                                          09-12-2021, 11:09 AM
