Sony OLED XBR65A8G no video, PSU problem?
  • cheebster
    replied
    Here is a better closeup picture of where these lines goes, to SVDD side of the Q6. What is SVDD ?
  • cheebster
    replied
    Hello, so doing a bit of poking around on this one i've found 2 shorted caps on the small area of the exposed panel pcb. Here is shown on the pictures the 2 caps corresponding to pins 4-6 of the flex on the tcon side, which goes to Q6 on the T-CON. Dead short on these 2 ! They are the 2 largest caps so i guess they are bigger voltages lines powering the backlight or the cells, seems to be closer to evdd connector. What does that mean ? No clue, short inside of panel itself ? I could inject voltage on the lines after removing caps and see if house catches fire ?
  • Diah
    replied
    Originally posted by cheebster
    Um, it seems that at the bottom of the TV, one of the 3.5MM ports say RS-232C/Remote. Would this
    expensive.. TTL adapter will be no more than 6USD..LOL
    remove the heatsink of yours MB and upload clear focused photo of it
    notice my answer could be delay as i am watching today soccer champion league lol
  • cheebster
    replied
    Um, it seems that at the bottom of the TV, one of the 3.5MM ports say RS-232C/Remote. Would this https://www.amazon.ca/Green-utech-Ad...ps%2C88&sr=8-4 Work ?
  • cheebster
    replied
    Ok, i don't know how to do that
  • Diah
    replied
    try capture boot log via TTL adapter
  • cheebster
    replied
    Ok, replaced t-con and same 4 blinks. Could it be that the code is stored into some memory or no ? Anything else i can try ?
    Update, it now blinks 6 times now sure what that could mean.
  • cheebster
    replied
    Yes to access it, but even there it's not fixable if it's the cof, only the CAPS. But bypassing the failed portion using taping/cutting/masking the pins is always an option i guess
  • Diah
    replied
    Okay will do. When a line of cell or anything is shorted on the panel itself, ive seen the quick fixes where people are 'taping' lines (seen this on lcd's) on samsung panels where there was failed COFS, but i always wondered it there was a way to more precisely pinpoint on which line the short is, so that you can either cut/isolate the fault and get a working picture minus one line or something similar. Also wondered if that technique was working with OLED in some way, haven't seen any reports of success with such issues on oleds like it did on lcd's.
    OLED Panel also have COF.. and also some time need banding if there line appears on screen,,, but the way to access to the area not easy... need to cut the metal which cover the area... for example
Name:	oled banding.jpg
  • cheebster
    replied
  • Diah
    replied
    Ok, thats good news. Do i need to migrate data or swap over the emmc? Thanks.
    first check no more blinking..
  • cheebster
    replied
  • Diah
    replied
    Same 4 blinks with everything connected but no evdd
    this indicated oled cells are not the reason....cross finger yours replacements t-con will solve the blinking
  • cheebster
    replied
  • Diah
    replied
    Yep, tried that, optical led is on and the tv stays on without the 4 blinks, with black screen. But that doesn't confirm it's either the panel or the t-con, right ?
    I ordered a t-con since it's cheap. Would swapping the t-con normally work without swapping the EMMC (at least give an image) ? Or the emmc needs to be swapped over to the new board before anything gets displayed ? Thanks.
    test with just the EVDD rail socket disconnected from PSU side and turn on.. check if you still have 4 blinks
  • cheebster
    replied
  • Diah
    replied
    Hello, same (about the same, a8h) tv here, 4 blinks on bootup. Tried Diah's post #4 suggestion, both 12v and 22v are being supplied to the T-Con, however panel stays black, nothing displayed. Should i try another tcon for the heck of it ? I see many voltages on the tcon near memory etc being generated by the inputs. No signs of physical damage to the panel at all. Should i at least get something displayed on the screen when 12v/22v is being fed to the t-con ? Any test pattern ? Thanks.
    at yours case you need just disconnect the lower LVDS between Main boards and T-CON then turn on the tv see if the 4 blinks remain or the set will start with black screen... yours sign of working are the audio optic port on MB will lit red and remain on also you could heat sound.$ we will know the condition of the OLED module..
    this post we are cutting the error collection pins on T-CON to MB to let the set complete boot... you can see the print chart of the lower LVDS on T-CON remarked with error.....
  • cheebster
    replied
  • mathlu
    replied
    Hello, Awesome thread. Very informative posts by Diah!
    Sony KD-65AG8 (should be the same as the XBR I think). Four red blinks on LED, no picture, no sound. Optical port lights up red, I was able to go through with factory reset as per Sony instructions (LED turns green, TV reboots and LED turns white for a short while then red blinks again).
    Ran T-Com standalone as in post #4. Voltages on PSB terminals:
    STBY: 3.48v
    REG_12V: 12.65v
    EVDD: 22.0v
    TCON_12V: 12.65v
    No picture what so ever on the screen. How do I know if the panel is dead or the t-con?
  • flusher
    replied
    Re: Sony OLED XBR65A8G no video, PSU problem?
    Yes Ive seen red light at optical port. Also I do hear music because I did hard reset holding vol - and power buttons and it was blinking green at front.
  • Spikeman
    Help on Video Problem on Dell Inspiron 7459
    by Spikeman
    Hi, I'll tell you the story of this PC.
    The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
    After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
    However, the PC later presented the problem in the video shared very frequently.
    The problem also occurs at startup, in the bios and when using it as a monitor thanks...
    02-27-2024, 10:17 AM
  • Gibon378
    Problem with stopping audio and video for no reason
    by Gibon378
    PC Specs:
    • CPU: Ryzen 5 1600
    • GPU: GTX 1080 Palit JetStream
    • MOBO: ASRock ab350 PRO4
    • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
    • PSU: XFX 650W (don't remember what model)
    • OS SSD: ADATA SP920
    • OS: Windows 10 21H2
    Problem description:
    Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
    11-19-2022, 09:41 AM
  • zimeyh
    Problem video A1502
    by zimeyh
    Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
    11-15-2023, 03:19 AM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • hugocarmo
    Grundig GV-250 Repair problem. (Video inside post)
    by hugocarmo
    Hi everyone.
    I have the following problem.
    I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
    In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
    01-19-2023, 06:46 AM
