Lg oled65e6p-u.buswljr
Re: Lg oled65e6p-u.buswljr
unplug ut from wall and re plug.. if its start STB power it on with LG SRC power only... see if you have the mainboards turn on optical led indicatorComment
Started in STB when I plugged in. Powered on with P-only on SRC. Heard the relay on PS but no lights on main board. Not in STB since I pressed P-Only on SRC.Last edited by rplewis; 01-29-2021, 04:53 PM.Comment
i use refreshing,
we need back to first test you did..
turn off the set from wall socket..... disconnect the mainboards from powerboards and t-con.... do the first test you did before 3 bridge between 3.5V and PWR-ON / DRV-ON / 12VT_ON
then plug on and see what you will have on the screen.Comment
Jumped everything like first time. Got 24 volts on 24 volt socket and 12 volts on the 12 volt socket. Nothing on the screen.i use refreshing,
			by AK_777Hi everyone!
I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and... -
			Full model of the TV is 65UJ6300-UA.BUSYLOR. TV was given to me by a relative as non-operational so I'm trying to get it working so I have a nice cheap upgrade for my living room. This is my first TV repair so if it sounds a little like I know what I'm talking about, I don't.
TV turns on and has audio, but backlight doesn't turn on. Getting 230v from LED+ to chassis. Also can't see anything with flashlight test. Another forum suggested I replace the LED strips because that's the most common failure on LG TV's and the flashlight test doesn't always show results.
			This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 04:30 AM
			by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
			by maxim2511My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
Then I get an idea to take it apart and clean boards from dust.
In side of Tv was not so bad, I take compressed air in can, and gently blow up.
Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher... - Loading...
