LG 86ul3e-t logo blinks and then nothing (but backlight stays on)
  • Panczis
    • Oct 2020
    • 28
    • Polska
    #41
    Re: LG 86ul3e-t logo blinks and then nothing (but backlight stays on)
    In post #11, on the picture driver_3_1.jpg are the two ribbons that goes to the TCON. But each pair of the driver boards is connected with the mentioned "U-ribbon". You can see the connector on the pictures "driver_3_4" and "driver _4_1".
    @budwich: Thanks for the hint, I will try that. I afraid, that the broken driver is the third board, so if it is a first in line, from the TCON, than it will not start until I find the fail. I thought that with two sides of the panel, when I disconnect the half, I will get a part of the screen on. But only when all four ribbons are conencted, the logo apears. Probably the whole panel must be operational to get the proper picture on the display
    • budwich
      • Jul 2015
      • 3097
      the problem with the "gross disconnecting" of the tcon to panel cables, you loose a lot of the signals that are required for the "sanity" of the system. By doing a smaller subset of the hardware "isolation", you have a better chance of getting some where in terms of system startup. Your pictures seems to show a problem more on the side than the bottom... my guess.
      • Diah
        • Feb 2013
        • 6379
        well i never saw LG panel display logo then go protection because of driver even if the screen smashed it will display and never send signal to shut down.. but LG mainboards it function with specific IR code signal, same to lg OLED even the original RC cant turn it on but service remote turn it with power only..
        this why i went to inspect the RC of this set and the operation manual of it... it till same story i writing it now.
        • Panczis
          • Oct 2020
          • 28
          • Polska
          #44
          I'm back, with some success
          I was able to run the LCD panel, so it doesn't stops anymore. What was done? I have blocked a error signal from the panel driver to the t-con board. With a scotch tape I blocked first 10 pins on the third ribbon, which connects the t-con and panel driver boards.
          TV started, but I had to reset it wit a service remote control, as it was in the power only mode, after my previous actions. I'm attaching the message that was shown by the TV in this state. It shows the software version and a short guide how to run it to the user menu. Now I have the picture from the external source (laptop with HDMI output).
          Probably I can see now, why it goes to the protection mode. There is a blinking line at the top of the screen. I made a video, how it looks.
          So now I need your help guys. What should I try to check, to identify the root cause of this blinking line. The line is visible only on the bright background. With a Youtube menu, or when the black backgroud is displayes, all works fine.
          Here is a link to the movie: https://photos.app.goo.gl/U6vQdPyucHBjrHT57
          • Diah
            • Feb 2013
            • 6379
            can you make remark of the 10 pins you blocked at T-CON ribbon on yours T-CON Photo
            • Panczis
              • Oct 2020
              • 28
              • Polska
              #46
              Take a look at the attached picture. It seems that the most important is PIN-9. I realized that the VCC is lost, after a first 2-3 seconds, when the display boots up, and shows LG logo. On the 9-th PIN must be an error signal, because a signal appears on it, after the VCC goes to 0V. It was hard to mask only the one PIN, so i decided to mask a few first pins. After this trick, it started to work.
              Now the only problem is this blinking line. Any ideas how to start? Probably it may be a bad capacitor. You are more experienced, could you advice me what to do?
              • Diah
                • Feb 2013
                • 6379
                so as you wrote pin 9 was active at time vcc cut off, so its sending SOS signal.. normally SOS signal will turn off the T-CON first. as i remember you wrote before you owned another T-CON, so with it trace the connectivity of this PIN9 if it goes to SPI/eeprom on T-CON via L or R
                • Panczis
                  • Oct 2020
                  • 28
                  • Polska
                  #48
                  The second t-con works in the same way. I think that I will try to look for the broken cap right now.
                  The screen works, but there are horizontal stripes visible on the left side of the panel. It is visible only from a short distance
                  • budwich
                    • Jul 2015
                    • 3097
                    does the "U" cable test that I suggested earlier have any impact on the display IF it does work.. or the panel does not work without your "tape mask trick"? It might help in determining if there is some smd cap on the driver board that is a problem.
                    • Diah
                      • Feb 2013
                      • 6379
                      i dont think there are any shorted smd.. its open circuit at the panel .. so the t-con shutting down.. i faced once with 65 4K made by vestel with LG IPS panel, there was small broken at right corner down on lcd glass which it break one line on the thin film print circuit under the glass , when i terminated this part the T-CON start working..
                      • Panczis
                        • Oct 2020
                        • 28
                        • Polska
                        #51
                        The problem is in the third driver so the U ribbon doesn't affect the display. When it is disconnected, than there is no picture on the display. The line which blinks is not broken from any sides. I will try to fix the masking, to disable only the 9th pin, to chceck if those vertical lines are show due to masking too mamy pins.
                        • budwich
                          • Jul 2015
                          • 3097
                          ok... thanks for trying this. Just ensure we are on the same page. You did the disconnect of the "U" cable without the tape in place or with the tape in place? You are certainly close to getting this working well. Hopefully the last step is within sight. good luck.
                          • Panczis
                            • Oct 2020
                            • 28
                            • Polska
                            #53
                            Thanks for all the hints.
                            Yes, with the tape or without it, when the U ribbon was disconnected, the screen was not working. Only the backlight started to work, but there was no LG logo shown up.
                            I'm quite happy with the current results, as I spent only 120Eur for the TV and list additional 150Eur for the parts. The bonus parts I will try to sell, as they were not needed.
                            Those thin lines are visible only from a really short distance. It was really exiting to learn how all those elements works togeter.
                            • nomoresonys
                              • 12206
                              • U.S.
                              #54
                              Another nice save, glad that monster didn't go to the landfill.
                              • events.b
                                Sceptre X505BV - Logo appears for 1 sec then backlight shuts off, LEDs tested good
                                by events.b
                                Hello, this TV currently has me stumped. As the title states, when I power on the unit, the backlight comes on for 1 second then shuts off. The TV is still on, and I can see the video if I shine a flashlight on the screen.
                                Using the LED backlight tester I was able to confirm all LEDs are illuminating and seem to be working correctly when independently powered by this tester, so that leads me to believe there is something wrong with the power supply board.
                                Perhaps the great minds here can help me figure it out, as I don't see any thing obviously wrong with it. The...
                                02-08-2021, 11:03 PM
                              • triplefour
                                by triplefour
                                09-13-2023, 10:43 PM
                              • JaquesPratt
                                Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                by JaquesPratt
                                I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                07-16-2024, 01:04 AM
                              • hollox123
                                ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                by hollox123
                                Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                1. Laptop keyboard doesn't work
                                2. The backlight on the laptop keyboard doesn't work
                                3. The x2 side LEDs (red) on the laptop don't work
                                The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                But I am strongly aiming that it is somehow a BIOS-related problem,...
                                05-11-2025, 08:05 AM
                              • signal.quest
                                Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                by signal.quest
                                I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                03-17-2024, 10:14 AM
