SONY KDL 43w805c does not accept commands
  • Diah
    replied
    Re: SONY KDL 43w805c does not accept commands
    Originally posted by Dobsuk
    Oh mate. Thank you for your patience First of all i do not have cool air. But could you share me some youtube video with the exact procedure i need to do? Thank you.
    the flux like water.. you try to let it reach all joint points under the chip. cool air i mean like hair dryer at cool step just we use the air pressure to let the liquid go further deep under the chip... then you heat it very well one time as you did before..
    i am sure here many good users from UK will help you by where and what to buy and how to use as they used it before over this forum
  • Dobsuk
    replied
    Originally posted by Diah
    still not fucked lol
    why dont use cheap way to buy Liquid Soldering Flux for example RF800 its less 3$ and push it around the chip with cool air to go on all pins then heat it once? you can see many video online.
    replied
    These may be compatible models, check the sticker numbers NOT the board numbers of any possible candidates:
    KDL-43W756C, KDL-50W755C, KDL-55W809C, KDL-43W805C, KDL-43W808C
  • Diah
    replied
    I think that i tottaly fucked up that board after the last heating
    [ATTACH]228435[/ATTACH][ATTACH]228436[/ATTACH][ATTACH]228437[/ATTACH]
    It looks i will have to lookiing for new one and now the queston is can i use the same board model even it is from TV with different sceen size?
    This is the cheapest option which i found, the same board model but accordin the descripriong is from KDL-65W855C.
  • Dobsuk
    replied
ID:	2060230Click image for larger version
ID:	2060231Click image for larger version
  • Dobsuk
    replied
    OK, guys. I tried few more times with the heat gun for different time but still nothing I think i am gonna burn this chip if i keep the gun for longer.....
    What if i leave it to work without the heat sink for longer? Just to overheat it on itself?
  • Diah
    replied
    Originally posted by ReeceyBurger123
    Diahs been smoking way too much man still to this day........
    If the demons came, the angels should flee LOL
  • ReeceyBurger123
    replied
  • Dobsuk
    replied
    OK. I will go for the heat gun again.
  • Diah
    replied
    OK, guys. I did not have to time to play with this board in the last days but i bought one 43w807c with faulty TCON board. I had one spare and swaped it and it is working now. But i took its main board and put in that 43w805c and it was working fine. So, defenetly the problem is with the mainboard. I am a bit worried to cook that MainBoard, Diah, thinking about the plastic parts on it.
    we know the issue BGA on mainboards ...also i am always against the cooking method.. so my suggestion always hot air or infrared heating source to users lack with equipment's and rework BGA ball for SMT Chip.
    so you need self to choice which source you can applying heat to the chip from the top side with temperature ca 280 degree for not less than 6 seconds.
  • Dobsuk
    replied
  • zen
    replied
    Thanks very much for the additional information .
  • Diah
    replied
    Originally posted by zen
    Main CPU could potentially have poor ball connection issue , but it's just not something i have had on this specific model .
    OP did many time hard reset.. it mean the NAND being erase and the Firmware again extracted and wrote back to the active partition of NAND. if there corrupted sector at chip for example it will not pass the erase. and if some one think the firmware corrupted , the firmware cashed on protected level. no access to any app or user to change or delete... beside it extracted correct after erase. the only things left the CPU.
  • zen
    replied
  • Diah
    replied
    Pictures of board are not clear , but the chip i mentioned is either the B G A type below the optical socket , or it may be under the white ceramic plate covering the CPU .
    its okay..
    MT5830BPHJ are the brain of this set it control all function.. include the IR.. if one BGA POINT get OPEN this function will be error.. IR are function and here we have the case. who knows which POINT.. but we still can guess the side of the chip where the OPEN POINT are.
    actually if the OP had Air Mouse the procedure will be more easy after he pass first installation then activate the developer Option & USB Debug so we can with adb proof the IR function.
  • zen
    replied
  • zen
    replied
    Sorry Diah , i'm just trying to help .
    I won't mention any companies in future , that i believe can help resolve the issue .
    The EMMC chip holds the full android operating system , and when data becomes corrupted , it can cause many different fault symptoms on TV .
  • Dobsuk
    replied
    Originally posted by zens electronics
    Hi apologies for late reply .
    Please don't cook the main CPU .
    Far as i am aware , this set suffers with EMMC chip issue & yes the company i mention microtech , based in Bolton can sort it .
    Regards Zen
    Yeah i sent them email 2 days ago and the answer was:
    Main emmc faulty we dona service for this model please be advised no netflix or amazon prime or chromecast apps are down please use fire stick which is 100%
    Then my question was "How come without Netflix etc.." and they answered me:
    Sorry if you want 100% working board please buy 1 on ebay to replace it we only repair the board with few apps that do not work that we advice and have plenty of our customers who take the service anyway good luck all the best
    So, not much helpful....
  • Diah
    replied
    Thank you, Diah. I will try this tomorrow may be as i am tired now. I appreciate you help, mate.
    And my toaster does not have door, mate. It is just 2-slice toaster.....
    then dont use it,,, lol you are in joking now.. oven will be better
  • Dobsuk
    replied
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • karthur
    Vizio D65x-G4 Volume changes on its own
    by karthur
    On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
    It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
    06-05-2025, 08:13 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • Ruptor
    Sony MHC 6600 volume clicking
    by Ruptor
    Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
    05-21-2023, 05:32 AM
  • jason123
    Sony STR-DN1030 Distorted audio when Volume adjusted
    by jason123
    New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
    All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
    First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
    Second thought was the ribbon cable from front display to control board (V-Flex,...
    06-05-2022, 12:54 PM
