SONY KDL 43w805c does not accept commands
  • Diah
    replied
    Re: SONY KDL 43w805c does not accept commands
    Originally posted by Dobsuk
    I can see the TV in my network as 43w809c, do you think it is good idea to change the model number from the service menu?
    no need at all, as both are same Specifications. just check firmware if its the last one.. if need update it. if this solved the issue good if not send the boards back to seller.
  • Dobsuk
    replied
    OK guys, i have some progression. I bought another main borad from 43w809c. When i switched the set on for the first time with all connected i saw again that self diagnostic screen with colours changing. Reset the TV - was the same. Then i switched off the TV, dosconnected the LVDS cable, switched it back on and connected that cable after few seconds when i could hear the sound from welcome screen and the picture came on. Now it is working but has some strange behaviour at moments - like does not hold the settings after retsrat and others. I can see the TV in my network as 43w809c, do you think it is good idea to change the model number from the service menu?
  • Dobsuk
    replied
    Check if the power supply has the required voltage and is steady if you haven't already.
    Checked with the other TV set. All good.
    replied
  • Dobsuk
    replied
    Originally posted by Diah
    different size could be different Screen driver.. this will put you again in headache get one as yours model and size for example
    Mm yeah. Just was looking for cheaper option
  • Dobsuk
    replied
    Does this tv use an external power supply?
    Yes, it does.
  • Diah
    replied
    Ok, my main board model is 1-893-880-21.
    I the same boards on Internet but for different tv models. Do you think they will be suitable:
    replied
  • Dobsuk
    replied
    Board 1 - 65W855C
    Board 2 - 65W857C
    Board 3 - 55W800C
  • Dobsuk
    replied
    No, I forgot it switched on during the night and now i think it is completly dead Looks there is nothing more i can do but to buy new main board
  • Diah
    replied
    And now:
    It is trying to survive somehow )
    did it survive or it take ticket to Mars Journey ?
  • Dobsuk
    replied
    And now:
  • Dobsuk
    replied
    Ok i did check with the ait mouse but could not see any changes pressing all F keys or the others. Restart TV few times but nothing. Then disconnected the TCON cable so to force some errors or something and now the TV stuck on this screen:
    And now i do not dare to touch anything.....
  • Diah
    replied
    OK, guys. I was away for a month and now i am back to this project.
    Diah, i found air mouse from a frined like this one:
    Could you give me some advise how to proceed, please?
    yes this is i8 air mouse keyboards.. nothings special need as try F keys and other.. plug the related usb receiver in Tv first then turn on
  • Dobsuk
    replied
  • Diah
    replied
    Do you think if i can find wireless keyboard will be able to connect it to the set?
    i use always i8 Mini when RC had issue or no RC in hand with any TV brand. or android TV BOX. because its driver type plug & Play
  • Dobsuk
    replied
  • Diah
    replied
    Yeah mate i tried that first - to unplug it and thw plug it in the wall without LVDS cable - nothing happened. Then i tried to reset it without this cable. No i am trying to put in standby mode but without success till now. It is just turning on every timw by itself. And yes, i can control the volume when i can hear the sound but that sound it is not comming up every time.
    keep pressing power on RC for more than 10 seconds.. the set should reboot
    EDID:
    you need to buy or ask any friend have I8 Mini 2.4Ghz Wireless Touchpad Keyboard, its work with android and it will work same way about control the Sony with serial command.
    replied
    I think you need to do a firmware update/pair, use the usb drive method, hopefully this kdl is one that will update by itself without needing you to do any remote clicks, some do some don't.
  • Dobsuk
    replied
    Yes.... I tried everything and still trying to do.something - restart, reset etc....
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • karthur
    Vizio D65x-G4 Volume changes on its own
    by karthur
    On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
    It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
    06-05-2025, 08:13 AM
  • Carlos#2003%
    Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
    by Carlos#2003%
    Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
    02-15-2024, 07:52 PM
  • Ruptor
    Sony MHC 6600 volume clicking
    by Ruptor
    Has anybody had the problem of the digital clicking from the volume control coming through the speakers. I guess the mute should activate as everything seems to have a mute from the analogue switch LC7822 to prevent output of stuff on the speakers but the mute circuits are really complex. The pcb is very badly manufactured as if it is over etched and not cleaned properly before being screen printed because I have fixed one fault but a wide track lifted off real easy with very little heat requiring extra repair. I dread touching the board so would like to go straight to the problem if someone has...
    05-21-2023, 05:32 AM
  • jason123
    Sony STR-DN1030 Distorted audio when Volume adjusted
    by jason123
    New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
    All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
    First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
    Second thought was the ribbon cable from front display to control board (V-Flex,...
    06-05-2022, 12:54 PM
