backlights in tp.vst59s.pc815
  • as1jc
    • Nov 2020
    • 16
    • philippines
    can some kind soul tell me how the back light circuit is controlled in this universal combination board. i'm new at this but i know how to use a meter.its almost impossible to work out this circuit tracing solder runs on double sided board. i have figured out that the backlight output is what APPEARS to be a rectified ac output from a transformer.what feeds and controls the input is a mystery.any responses are welcome
    Re: backlights in tp.vst59s.pc815
    You need to give more details and pictures so we can see what we are dealing with.
    • Astonished
      Fixing the Charge Circuit of the Batteries of the DC Motor
      by Astonished
      Hi friends of electronics
      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
      Please help me fix this circuit.
      (the datasheet of the IC: https://pdf.datasheet.live/28...
      01-28-2025, 06:24 AM
    • Tarot Superstars
      Short Circuit tester
      by Tarot Superstars
      Hello.
      I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
      The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
      Link
      The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
      https://www.youtube.com/watch?v=0eixDdCpiO4
      My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
      09-25-2023, 09:11 AM
    • Alimash
      op amp circuit function?
      by Alimash
      I am repairing a ups which doesn't turn on ,it has the following ICs:
      SG3525 used to drive inverter mosfets.
      couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
      A LM358 and TL074 for control mechanism and of course the uController.
      The SG3525 is shutting down every time the ups is turned on.
      I want your help to know the function of LM358 and TL074 in the system.
      I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
      07-31-2025, 07:45 AM
    • M1NEBLANK SHOW
      MSI B250 Gaming M3 Short circuit in CPU power supply circuit
      by M1NEBLANK SHOW
      Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
      (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
      Schematic and Boardview here
      04-04-2025, 03:57 PM
    • max789
      Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
      by max789
      Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
      I made the following tests:
      1. Disconnected the main board from Power Board = backlight works.
      2. Connected the main board and disconnected the T-Con = backlights does not work.
      So I ordered a main board from Ebay also BN41-02156A but from...
      01-18-2024, 06:56 AM
