Replacing nand/flash chip on TV's
  • sigmeyer
    • Feb 2020
    • 158
    • Serbia
    Hello , i was wondering how would i go about replacing nand chips on TVs?
    Recently i had a few tvs that i couldnt fix because one had a corrupted nand chip and one just kept rebooting *psu fine) . Can i just find a random nand chip , solder it on , then boot with usb firmware ? would it update or do i need to Pre-write the chip before soldering it?
  • William1967
    • Nov 2017
    • 215
    • Netherlands
    Re: Replacing nand/flash chip on TV's
    No, you can not use an empty nand and start the tv up via USB. Firmware is used to update and that is much different. For example i have a few Sony's with more than 12G software inside the nand, the firmware is only 1,2G
    • mazmaz
      • Jan 2021
      • Iran
      for re programming a nand or emmc chip,
      You should remove it and place on universal programmer and burn a good dump backed up file and re solder it again exactly in its place.
      or in some circuits you are able to do onboard programming by some universal programmers without removing it as JTAG.
      • tranquility
        Onkyo TX-NR809 – no hdmi, DTS or NAND chip ? stuck at starting kernel
        by tranquility
        i want to repair an Onkyo TX-NR809 receiver.
        symptoms:
        on power on, display appears and i hear one click. enue functions is given.
        - no hdmi output
        - audio output not tested, but i think it is not there
        - usb sticks are not recognized
        if i read out the chips with display+standby button + tone+
        both dts show only ????
        chip is D830K013BZKB4
        things i have done:
        - reflow of the dts chip without taking off and reballing
        - changed the aluminium caps without the big one with 25v because i dont...
        08-25-2025, 01:04 AM
      • zoltor
        Canon G3430 has a lightning flash after the firmware
        by zoltor
        Good afternoon. The Canon G3430 is lit by lightning after the firmware, it does not respond to the buttons. I did not flash it, they brought it with traces of soldering, and all three chips. SPI - IC401 25Q128, IC402 25Q32, IC403 M24128. The SPI flash drives may have been confused in places. The QM8-0985 formatter. I've tried all the firmware available on the Internet, and the result is the same. I ask you to send dumps of chips, if someone has the same revision of the board, also tell me if the location of the SPI flash corresponds to the position numbers. Thank you very much in advance.
        09-17-2025, 12:40 AM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • ebugs
        Asus laptop EC/SIO chip replacement
        by ebugs
        Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
        I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
        I found the EC chip...
        09-14-2024, 02:09 AM
      • ekozeko333
        by ekozeko333
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
