65UH6030 Backlight No Picture has function
  • Plurxtc1
    • Oct 2014
    • 136
    I have a 65UH6030. There's no picture but the backlight turns on. T-Con has 13V. The first picture is the Panel Driver R2, I marked with a pen that was short, but when I removed the capacitor, the line is short which means the capacitor was good so I placed it back.
  • Diah
    • Feb 2013
    • 6614
    Re: 65UH6030 Backlight No Picture has function
    did you try disconnect one ribbon cable at time.. to see if half screen turn on white.. also did you saw on the panel edge boards you have on each side U ribbon cable.. if you have then try the disconnection of ribbon start at one at time of those U ribbon cable.
    • Plurxtc1
      • Oct 2014
      • 136
      I did, the right side is WHITE, but the left side shows up no picture. I've already had the T-Con replaced.
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • Mgiffune
        by Mgiffune
        06-09-2024, 10:28 AM
      • Ierwin
        by Ierwin
        05-13-2025, 03:31 PM
      • Superbee_dad
        Sharp 80” long short flash backlight error - Help
        by Superbee_dad
        Hello Sharp TV experts
        Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
        > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
        > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
        01-24-2025, 11:51 PM
