Re: Sony Bravia LCD KDL-32L4000
You may have one of a couple of problems: CCFL tube gone bad. PSU/Inverter gone bad.
Most likely it's the PSU. You didn't mention if it's generating high voltage for the CCFLs...
You need a cap ESR tester to test the caps in the PSU. They often are NOT visibly bad but reguardless have failed.
You should also test all transistors for shorts.
Many PSUs have a switch that when switched will cause it to ignore the turn-on signal lines such that it will simply turn on. This may help you diagnose the problem.
