I picked up a 2013 Samsung plasma model number pn60f5500 for free today. Owner said the standby light would flash. I had a feeling that it was all due to a bad ceramic cap(10uf 50v) on the ysus board. I was right again! It works perfectly. I have repaired other models that have 3 of them in parallel before, but this one only had one with holes unused for a second one.
Pn60f5500
Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
2/ Figure 1 Gfx-D500-B Front Facing
3/ Figure 2 +5v supply (zoom-in)
Intro:
While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...12-07-2023, 09:55 PM -
by djtyDevice: Laptop
Brand: Apple
Model: MacBook Pro
Board number: 820-3787-06
Problem:- no keyboard, no trackpad
- Fans Spinning fast
no reaction on KB, only power button andd ctrl alt shift, which are on keyboard connectore are separately on the KB pinout KB backlight is present the PP3V3_S4 and PP3V42_G3H one keyboard connector J4813 are present on keyboard
external USB keyboard works Should touchpad be connected to motherboard for KB to be working?
by Silent18Guys do you have razer blade 14 2013 rz09 0102x bios....
thanks in advance!!!-
Channel: BIOS Requests ONLY!
Hey wonderful that you got the system booted .
I came across this thread in the hopes to find a schematic for the a1481 , I believe they don't exist . Please correct me if I'm wrong. Also if you'd post them i'd be greatful .
i have a Mac Pro 2013 a1481 with led 2 , 3, 5 remaining on and then the system tries to boot to s0 , with led 6, led 7 ie s0 and s4 turning on simultaneously and Turing off .
I don't have a doner board nor schematics … hence trying to figure out where to start to probe . I've checked all connectors and cables which a seated and working fine... -
by bogosortHello,
I have a MacBook Pro 15” A1398 2013 that has no backlight, but I see an image when putting light through the logo. I noticed that when the screen is plugged in, I get a 300 ohms short (see image).
When unplugged, the short is gone.
Any idea?1 Photo - Loading...
